Televison & Video Logo
Question about Argosy Televison & Video
How to Fix my Argosy HV335T-0020T HD TV Full 1080p Network Media Player
I Have Argosy HV335T-0020T HD TV Full 1080p Network Media Player and i cant use him with any tv and now i dont see him when i plug it to my Pc computer What is an easy way to fix it ?
Roger R
  • Argosy Master
  • 1,703 Answers
if you're using bluetooth to connect to the tv, please restart all devices and try again. Thank you.
Posted on Sep 30, 2022
I changed out my hard drive and now the light doesn't flash when booted up. It doesn't see the hard drive.
retest your steps and follow the instr. manual or the instruction coming with the hard drive replace. However you must go to the Menu, AND RESTORE TO THE FACTORY DEFAULT.
God bless you
SONY BLUERAY FULL HQ1080
you want to watch hd 1080P? what is your question? to watch full 1080p you need you bluray player a bluerays disk and a tv that can actually handle 1080p, just because a tv is new and "big" wont ensure it can handle 1080p
I can't install the firmware from the CD. I have downloaded DataInstaller.exe on my computer, but it doesn't work. what can you do to help me to enjoy my HV359T?
There should be a couple of other files in the folder as well as datainstaller.exe.
Download the latest firmware from http://argosy-eg.com/downloads/HV359T/HV359T_R1.99_ari_702_r199.zipunzio the folder then run datainstaller .exe with the Argosy connected via usb.
I updated last night but I can't see any MP4 files, don't suppose any fellow owners have the same problem or advice for me to fix it?
2answers
Well everytime we hook up the HDMI for the playstation 3 to the tv it says invalid format how do i fix this
You must make sure your playstation and your TV set are both set for the same video format (1080p, 1080i, 720p, etc.).
You can either go through all your HDTV formats until it synchs up (give each a good 20 seconds or so before moving on), or you can open the display menu for your PS/3 using a different video connection to your set (i.e. composite), setting both to match, then switching them to HDMI.
1helpful
I have hooked up my br to an onkyo home theater through hdmi. i now get an unusable signal on my flat screen. This also happens when I hook it up directly to the tv. What can I do to get this to work
hi,
The Blu-ray player outputs full HD VIDEO (1080p) through HDMI, if your tv is not a full HD one then you can't see the video. Do one thing connect the Blu-ray player to any full HD tv and go to it video setting. Down scale the video to 1080i. All HD ready tvs supports only resolution up to 1080i. only full HD tvs supports 1080p. Down scale the video to 1080i surely you will get video. Also check the version of HDMI cable you have used. It should be 1.2 or above.
ok
2answers
I upgraded my argosy hv335t firmware to 2.3 then rolled back to 2.1c (all upgrades done from a usb device which was safely removed from pc) after the player did the upgrade it restarted then got stuck on...
go to this site: http://www.argosyusa.com/download.asp?DefaultTab=0
there are two different verrsion of the HV335T one with "VR" after the barcode and the other with no "VR" after the barcode you will see what version is the one you need
for no "VR" code are this firmwares D2.35 (beta) V2.3 V2.1c V2.0 V1.01 (original in the player)
for "VR" code are this firmwares B1.35 Same as D2.35 for HV335T VR R1.1 Same as V2.1c for HV335T VR so, download the one you player needs and do the upgrade
Leo
How do i get my tv to run 1080p
A 1080p set will only show 1080p if the broadcast or satellite co sends it. I don't know of any cable co's doing that as yet. True HD isn't in full motion as yet. 720p is your best right now unless you have a Blue Ray DVD Player along with a 1080p full hd movie then you can watch full HD.
A lot of stations are running 1080i which is good for slow motion movies. 720p is best for fast action movies.
1helpful
Can't see anything on the tv screen when i turn on my argosi
When connected to the TV, press the "Setup" key on the remote and go to "Preferences".
Now select the option "Factory Default Setting" and press OK. This will solve all the issues.
2answers
Argosy 359t mobile media player freezes at the loading screen.
Have you tried another drive in the unit, maybe the drive is bad or having a problem.
KCMT
Top Argosy Televison & Video Experts
Marvin
Marvin
Are you an Argosy Televison and Video Expert? Answer questions, earn points and help others
