Question about The Office Equipment & Supplies
Kenmore 66515772990 has lock led flashing. Tried unlock by holding button but stays flashing
Also tried reset procedure as seen on YouTube, and sometimes the cancel light will flash too, but no resetting.
Posted by Edward J Butkiewicz on
Roger R
  • The Master
  • 1,804 Answers
you did well to check the resources you've used, at this point, I would recommend calling a repair person to help fix your dishwasher . Thank you.
Posted on Sep 30, 2022
Resetting Master pin on rona Electronic Deadbolt lock
Google
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
Remove batteries and put them back. You will hear a long beep and a short beep.
Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
Key in master PIN and press UNLOCK button
Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
Release 0 button and you are in the Add PIN mode
Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
make model resetting lock
https://www.google.com/search?q=resetting+Master+pin+on+rona+Electronic+Deadbolt+lock
Locklight stays on,dishwasher won't start. How do I reset?
Kenmore Dishwasher Repair in 3 Minutes! - YouTube
? 3:39
www.youtube.com/watch?v=sFNSUHn9_cc
Dec 21, 2013 - Uploaded by Kelly Mercer This is the most common cause of the dreaded no power condition. Mine failed just days after the warranty was
1helpful
The locked button won't unlock
Hold down the no heat dry button for about 5 seconds or so.
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
1helpful
2answers
My bmw 320d remote wont lock car however does lock the car with the key its a 55 reg
Programming
When
Key batteries completely discharged. Key batteries not replaced within 60 seconds. Key added or replaced. DO NOT press remote control buttons during battery replacement.
How
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 1 [1]. Press lock button Fig. 1 [2] briefly 3 times within 10 seconds keeping unlock button [1] depressed. Release unlock button Fig. 1 [1]. Some models: LED Fig. 1 [3] flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Some models: Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously
Later keys with bmw badge on key. Battery can not be replaced
Battery in key charges while driving
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
23helpful
2answers
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Kenmore dishwasher 665 lockout problem
You may have a bad control console.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
3answers
Door locks dont operate with remote key fob
Touch Key metal to lock cylinder metal then unlock
Top The Office Equipment & Supplies Experts
vince
old marine
old marine
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
