Televison & Video Logo
Question about Samsung Televison & Video
Good Morning, I have a Samsung UN75MU6070F TV. No standby light, reset the tv and remote controller per instructions. I removed the back panel and found the fuse open on the PCU. Any suggestions?
Posted by Randy Storr on
Roger R
  • Samsung Master
  • 1,698 Answers
please don't alter the inside your device as it could be a fire hazard. Any professional work required should be done by a company like geeksquad or your manufacturer.
Posted on Sep 29, 2022
Testimonial: "Roger, My apologizes for misleading anyone that I was going to alter my tv in anyway. I just retired from a profession where I trouble shot solid state circuit boards and electrical systems. Due to only being able to submit 200 characters, I couldn't give all the information. I am looking for any help as to why it would have blown the fuse. Thanks for your reply, I will find another source to answer my question."
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Polaroid TLX-01511C LCD TV REMOTE WONT WORK
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
11helpful
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
2helpful
2answers
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
4helpful
2answers
Samsung flatscreen wont turn on but red light is on showing power ..my son used sleep timer last night
with tv in standby press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu DO NOT CHANGE ANY SETTINGS
look at list you will see reset
ONLY USE DOWN NAVAGATION KEY until RESET is highlighted
then PRESS RIGHT NAVAGATION KEY the tv will reset
PRESS STANDBY TO EXIT
the tv will need retuneing after
hope this helps
4helpful
Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
4helpful
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
WARNING TV WILL NOT WORK IF YOU CHANGE ANY OTHER SETTINGS
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Turn ON TV AND RETUNE
12helpful
5answers
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
2answers
Can't turn on tv
Unplug the tv for 30 and plug back in.
Marvin
Marvin
