Question about The Office Equipment & Supplies
U-line U-co2175fs-01 Display says "off" and power button doesn't turn unit on. What could the issue be?
Posted by Tyler D Ross on
Roger R
  • The Master
  • 1,804 Answers
Please attempt to hold down the power button for 10 seconds to check whether the ice machine comes on. If not, you can switch power outlets and attempt this again. Thank you.
Posted on Sep 29, 2022
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
I have a kx-tda30 unit and one of the phones a kx-dt333 is having issues with line one. when answering it i have to press the intercom button when all other units are assigned to co.1 what i would like to...
A couple of things come to mind, but what happens when you press PROG and the line 1 button on an idle phone? If it doesn't say Single Line-001, that could be something. Dial 0 01 and press ENTER. Now CO1 is back under that button.
The other items deal with line preference incoming so save it for later.
Carl
3helpful
Flash not working error sign E 91;01 on the lcd screen model dscw110
The E:91:01 is the self diagnostic code display of the Camera which indicates the symptom of the issue. This can easily be identified with the help of a authorized service technician.
The E:91:01 code indicates the abnormality of the Camera when the Flash is being charged. Normally this can be resolved by some normal troubleshooting steps and if not changing the Flash unit.
Try recharging the battery in the Camera to Full and then power resetting the Camera. To power reset the Camera, remove the batteries from the Camera, press and hold the power button of the Camera for 30 seconds and then re-insert the battery pack after 1 minute. If the issue persists, try INITIALIZING the Camera. To Initialize, press HOME, select SETTINGS--> MAIN SETTINGS 1-->INITIALIZE-->OK
If the issue persists after resetting and initializing, service may be required to resolve the issue with the Flash unit
Thanks for using FixYa
1helpful
My camera´s flash doesn´t work :/ and it says E:91:01 what does that mean? can I fix it? or my camera is useless
The E:91:XX error code appearing on the Camera screen is due to an Internal Hardware malfunction.
The E:91:01 error code may be due to the issue with the flash unit in the Camera. This can be resolved by checking or replacing the Flash unit.
Before that try the normal troubleshooting steps like power resetting and factory resetting. If the issue persists, it would be better to get the unit serviced at the Sony Authorized service center.
My HK 3380 doesn`t turn on...
If the display does not turn on, then you have a power problem. The unit is not completely turning on. Since you opened up the unit, give it a sniff test to see if there is any burnt odor inside the unit. Check the fuses also. Have a look at the transformer board. It may have several fusible resistors sitting high on the board. If they burn open, there is no power to the display/cpu board.
15helpful
3answers
Power and attenion keeps flashing says turn power off then on
Perform a partial reset of the HP All-in-One
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Need to know how to use mic with dp-01
First you'll need to know if your mic is dynamic or requires phantom power. The DP-01 does not provide phantom power, but the DP-01FX and the DP01-FX/CD units have the option of turning on phantom power for their two XRL mic jacks. The DP-01 simply has 1/4" jacks for mics. Typically if your mic comes with a 1/4" plug it will be dynamic, but that isn't always true.
Plug it into the mic/line jack in the front of the unit and turn up the input volume knob. Then depending on which of the two inputs you used you'll have to press the Assign button (A or B) and then the rec button over one of the tracks and turn up the track fader. You'll also need to insure that the master fader is turned up and you should then be able to see the meters moving when speaking into the mic and hear the output in your headphones.
To record simply press the rec button on the assigned track again (it will light steady) to arm the track for recording and press the play and record together.
Hope this helps.
bd.
U-Line CO2175FS-00 Echelon
Depends, if you have the later models, you can able to retighten it a the handle, it is removeable, but if you have the old version, too bad, you have to replace the whole door. You can try to call U-Line at 800-779-2547 to see which one you have.
12helpful
3answers
Displays E 01
Talked to the nice lady at West Bend. Apparently, the problem comes up when the unit is "cold"... whatever that means. She said to plug it in, wait a second, then push the power button, then "cook" immediately. No pause. Don't hold either button. I tried it, it worked on mine.
Apparently, this a feature for some reason.
Top The Office Equipment & Supplies Experts
vince
old marine
old marine
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
