Washing Machines Logo
I have a Doosan DL 400 that won't travel. Error code EE comes up. What should I look for?
Posted by Simon Fullbrook on
Roger R
  • 1,742 Answers
I would first search behind any tire on the machine to find out if anything got lodged where it was not supposed to. Also, for error code EE, please reference your products manual. Thank you
Posted on Sep 30, 2022
EE Fault code means
make model (what it is) is needed for all questions, or we have to guess!
The EE error code indicates an error on the main control board. This error code is usually fixed by unplugging the washer for 10 minutes to clear any memory errors on the control board.May 3, 2017
LG Front Load Washer EE Error Code - How To Repair?
Te 522 error EE
EE stands for Energy Efficient. The problem could be:
1) a bad thermostat 2) inadequate ventilation (blockage) 3) a bad controller board if the unit does not come on following this display.
The manufacturer pretty much decides what these specific codes mean. You might have to contact them.
Shows ee and will not come on
EE is an error code. I cant help you with this one , but it means something has failed. Try the Fedders site or a Fedders Agent who may be able to state what the EE code means and then see if you can purchase or obtain a Tech to fit the part required.
2answers
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
2helpful
2answers
I have a fujitsu invertor AOT54LJBYL and the key pad comes up with EEE
When EE:EE is displayed on remote control , press "Energy Save" &"Zone Control" buttons simultaneously for longer than 3 secs. The error code will then be displayed on the LCD.After getting error code, please write here to get solution. Thanks.
Open Questions:
0answers
LE and E6 Error Codes on LG Top-Loader I got an LE error code on my LG top-loading washer model #WT5070CW. Tried to reset it a couple of times, but it kept coming back. I understand that this code indicates that the motor is locked because the load is too heavy or any one of a number of other possible reasons related to the motor, rotor, etc.. I emptied the load and the error kept coming back, so I ruled out the load size as an issue. I turned the unit on it's side removed/inspected the rotor, which looked fine. I noticed the three screws that attach the Brake Actuator to the Drive Shaft and Shifter Assembly had somehow come loose, fell out and went missing, and the plastic Brake Actuator part had been cracked. I assume this was the cause of the error, and replaced this part with a new one. I also needed to secure this part with some larger screws, since the originally sized screws had worn out the threads where they were screwed in. I also looked over the wiring and didn't see any damage or wear. Next, I removed the stator and replaced the hall sensor with a new one just in case there may have been an issue with that part. However, when I reassembled everything and tested the washer, the drum still doesn't start to spin, and after a few moments, I get the LE code. Finally, I also changed the Washer Shifter / Coupling part, since I thought it may have been a little worn, in the hopes that that would solve the issue. When I restarted the machine, I then got an E6 error code. (Now, I'm not sure if I'm even past the LE error, or whether I have two errors at the same time.) I see the guidance online recommends looking for paper clips or coins stuck inside the washer tub, but there's definitely nothing like that. I'm reluctant to order more new parts as may be recommended in line with this error (clutch, drive shaft, etc.), and would welcome any guidance or suggestions on all of this. I've also been "agitating" my significant other by caving in to her wishes and calling a technician or ordering a new washer. Any suggestions as to what else I should be looking out for, which may be causing this issue, and anything else I can do to troubleshoot this issue? Thx in advance.
Top Washing Machines Experts
Marvin
Marvin
john h
