Televison & Video Logo
Phillips TV will turn off before showing Phillips on the screen
I don't have a remote and after pushing power tv will turn off sometimes I can push channel Up and down buttons and it will go to Phillips on screen and go to channel and stay on but generally turns off
Posted by Michael Brown on
Roger R
  • Televison & ... Master
  • 1,698 Answers
it sounds like one of your tv buttons is getting stuck. And if it's the power button, then your tv would turn off. So, you would need to pull out the button after it's been used. Thank you.
Posted on Sep 29, 2022
2answers
My Phillips 42PF7320/79 Flat Panel TV won't turn on, screen stays black but green pwr light is on, after a lil while the green light flashes a couple of times then goes off itself completely
This idea may be worth a try. Look at the buttons on your remote. If you see a button that is marked "TV" give that button a push and then give the "Power" button a push. Wait for a while! sometimes this takes a while to turn the TV on or off. You may have to do this a couple of times depending if the power was off or on when you started doing this. If you started with the set off, sometimes it takes a while for the set to turn on.
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney ([email protected])
Have a Phillips flatscreen tv. I can't turn it on with the remote but can turn it on by pushing power button onthe side of tv. Batteries are new.
Hello, you could still have a worn out power key. Turn on the power manually(power key on the TV) then select channels/adjust volume/press the number keys.If all these work on your TV, then you know another remote is needed.
I have bigscreen phillips tv and sometimes the volume goes in and out and now the volume and menu dont show up at all on teh screen when pushed on the remote
You have a bad signal board. To be sure this is correct...unplug your tv for several days or even a week or so. The tv will work fine for a few minutes and act up again. A very common problem for this brand. These are pricey and will need a complete geometry setting by a tech.
2answers
1999 RCA mm36100 TV The buttons on the front panel are all messed up sometimes they work and sometimes not. The menu keeps popping up from time to time randomly and sometimes runs though the menu items all...
Bad push button board, best thing to do is just unplag the board and use remote to operate TV, board is mounted under front cover where button are.
Need remote code for mitsibusi tv
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
1helpful
Television
Try this: turn on your tv.
Push and hold code search button until the led light stand.
Release him push and release the device button( Tv,Dvd,Vcr),now you got to push and release the power button until the tv turn off now you push and release the enter button and the code are now on the remote memory.Good luck
My girlfriend took the batteries out of the Phillips universal remote. When she replaced them with new ones, the remote would not respond to the Toshiba TheaterView big screen television it was programmed...
first push code buttom then press tv then start pushing power buttom until tv go off (do not push power again after tv go off if this happen need to do everything again)then press enter and try again
78helpful
9answers
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
6answers
Lost code
what make & model
Top Televison & Video Experts
Marvin
Marvin
