Heating & Cooling Logo
Need operating instructions for Sunhouse Storage Heater model SH12A-79342S
Posted by Alison Butters on
Gaurav Malhotra
If you are looking for the High quality Laboratory Heat Sealer to test your product quality, then we suggest that you to go with Presto. Presto is known for one of the best and premium design Heat Sealer manufacturers in India. We believe that it will be delightfully surprised to see some of the latest innovations in both concept and design. We will be happy to supply this testing instrument at your convenience.
Posted on Sep 30, 2022
Testimonial: "Nothing to do with what information requested"
1helpful
Is Optimus radiator light suppose to go on & off? Got at yard sale
Not sure what your model number but following is for H-6003.
Search "optimus radiator manual"
OPERATING INSTRUCTIONS:
Plug the power cord into a wall outlet
(110-120V AC, 60Hz)
This heater has only one (1) power setting, pressing the
rocker switch to the ON position, it will give you 700 watts
of heat. When you want to switch off, then just press
the switch to the OFF position.
When the unit is turned on the power indicator light will
illuminate to tell you that the heater is functioning.
THERMOSTAT INSTRUCTIONS:
Before setting the thermostat, allow the heater to operate
and warm up the room. You need to set the thermostat
on MAX to start the heater.
When the desired temperature/comfort level is reached,
lower the thermostat setting until the heater stops
operating.
The control will now automatically maintain the pre-set
temperature level by turning the heater ON and OFF
Cannot get it too light
PDF]operating instructions and owner's manual - Rural King
www.ruralking.com/.../MH9BX_Portable_Propane_Heater_Manual.pdf
light, adjust or operate the heater. PORTABLE PROPANE HEATER FOR RECREATIONAL AND COMMERCIAL USE. MH9BX. Model #. 02/09 32030. MR.HEATER, INC., 4560 W. 160TH ST., ... Get fresh air at once! Have heater serviced. speciFicatiOns. MODEL NO. .... Some people cannot smell well. .... Buddy series hose.
Mr. Heater Portable Buddy Propane Heater - Bass Pro Shops
www.basspro.com/...Heater-Portable-Buddy-Propane-Hea...
Bass Pro Shops
I just bought irect water heater model HL40Sk ,is heater comes with legs it was nothing in corton ?
It most likely is a wall mounted model. Did it come with instructions? That will show you how to install it.
Creda storage heater manual
I'm not a heating expert, but according to the information I could find, Economy 7 utilizes cheap electricty at night, during off-peak hours (7 hours) between midnight and 7AM. Economy 7 costs about 4p per unit compared to peak electricity, which is about 10 to 15p per unit. If you do not have Economy 7, you can request it FREE of charge from your electricity provider. You will either have one meter with two readings or two separate meters. A two tariff electric meter will record the electricity used during off peak times, so it can be billed, separately, at a lower rate. If you have two meters, one meter controls on peak daytime electricity and the other controls your night time economy 7 electricity.
I would need to know what model Creda heater you have installed in order to determine how energy efficient it may be. I also will need the model so I can determine operating instructions. If you need further assistance, please post back and let me know. I hope this helps.
1helpful
Don't know how to operate storage heaters
Here is a link to a video, that will explain and show you how a storage heater works. It's really a very good instructional video. http://www.youtube.com/watch?v=bXrbk-cPWG0
I hope it helps you and thanks for choosing FixYa.
We have recently moved into our house which uses Dimplex storage heaters ,but I have never used them before how can i use them to the best effeciency
This type of heater is found primarily in European countries and Australia. They are designed to take advantage of Off Peak Electric Rates. Thereby, saving the consumer on their electric bill.
Below is a link that will explain to you the proper operation of your storage heater. You can print it for future reference, if you like.
http://www.ehow.com/how_7343441_operating-instructions-storage-heaters.html
Hope this information helped answer your question.
1helpful
We have Dimplex XLS storeage Heaters and no operating Instructions. Our electricity bill is very high so we must be doing something wrong. Can you help
Not sure if this is the model of your storage heater but it may help
http://www.storageheater.co.uk/Manuals/Dimplex/XLSN%20Operating%20Instructions.pdf
53helpful
5answers
Operating instructions for creda storage heaters
how do you regulate the heat from creda storage heaters model No 79163 /79151 /79141 they have 2 dials on each heater,I was told the dial on the right turn up to 6 its highest point & the left dial to its lowest number 1 .But i got up this morning & its like a sauna
Open Questions:
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
