Washing Machines Logo
Question about Zanussi Washing Machines
Zanussi Aquacycle 1100 XC - when trying to start the machine the door clicks 3 times and then I get a error / beeping sound.
I have just swapped the door interlock which didn't change the problem.
Posted by Jason Jackson on
Roger R
  • Zanussi Master
  • 1,646 Answers
Please clean out the interior of your machines and clean any filters as necessary, then attempt to run again. If this continues, please call Zanussi at 03445 610 645 to help overcome the issue. Thank you.
Posted on Sep 30, 2022
Turn on my jet system 1200 fj 1254w xc just makes clicking sound
Obviously appeared family error code E40 (visible to the customer) what means a problem with door interlock. Could be: door open (mechanical failure), door interlock malfunction, the problem with main PCB (triac) or wiring. In service mode you can see exactly error code: E41,E42,E43,E44 or E45.
Dado
Zanussi fle1416w aquacycle 1400 xc , on some cycles it does not take in any water into the drum although water goes into the draw, clothes are totally dry at the end. Some times it keeps pausing and...
Check drain hose has not dropped down. that the height of the waste pipe is at least 50 cm high and the waste hose has not been pushed a long way down the stand pipe. all these things can cause the machine to syphon out all the water it has taken in. it more **** to happen on delicate programs with higher water level the beeping would happen after 5mins. comment back if this not the case
1helpful
Zanussi aquacycle 1200 washing machine
The Timer/ECU is likely failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
I need to know what the model no is for a zanussi aquacycle 1100 xc washing machine as I have a problem with the drain um and would like to urchase a new one but do not know the model no of the machine
if you look on the back of the machine there should be a label there with the model number. (Or inside the users manual)
http://www.zanussi.co.uk/ or go here and click on 'Contact Us' to find out directly fron Zanussi.
1helpful
My zanussi Aquacycle 1100 wont start. A clicking noise starts after I try and start a wash. I heard it could be a door interlock that requires replacing. Is this easy to replace?
door interlock is easy to replace.
undo the plastic clamp that holds door gasket to cabinet. peel back in area of door lock. door lock is held by 2 screws on outside. undo these ans lock comes off. there may also be a small diameter hose as well to door lock which take off as well.
reassembly is just the reverse
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Top Zanussi Washing Machines Experts
Marvin
Marvin
sheakhly
Level 1 Expert
mark warfield
mark warfield
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
