CAT6A cable enables the transmission of up to 10Gbps ethernet data rates over a single cable run up to 328 feet which is capable of supporting data transfer rates at a maximum bandwidth of 500MHz so CAT6a cable is better than CAT6 cable. It is used for CCTV and data networks like class EA networks and for creating a wired network in the home. It is used by gamers, noobs, and pros alike because of its reliability and high speed. CAT6Acan serve as a supplement or bridge with fibre networks.
Description
1 50A** I/P fuse panel 2 - Not used
3 - Not used 4 - Not used
5 - Not used 6 50A** Anti-lock Brake System (ABS)
pump motor
7 30A* Powertrain Control Module (PCM)
8 20A* Power door locks, Remote entry
9 - Not used 10 - Not used
11 50A** Starter relay, Ignition switch
13 20A* 4x4 Motor 14 - Not used
15 - Not used 16 40A** Blower motor
17 20A** Auxiliary cooling fan 18 - Not used
19 - Not used 20 - Not used
21 10A* PCM memory 22 - Not used
23 20A* Fuel pump motor 24 30A* Headlamps
25 10A* A/C clutch solenoid 26 - Not used
27 - Not used 28 30A* ABS module
29 - Not used 30 15A* Trailer tow
31 20A* Foglamps, Daytime Running Lamps (DRL)
32 - Not used 33 15A* Park Lamp
34, 35, 35, 35 & 37 Not used 38 10A* Left headlamp low beam
39 & 40 Not used 41 20A* Heated oxygen sensors
