Televison & Video Logo
Question about Sony BRAVIA Televison & Video
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
The TV works just fine but the input bar on top stays there and does not disappear as it used to. Also when I try to go to the menu or access any functionality using the navigation buttons the message "Powering on. Please wait...". apperas and I can't go any further. Could anyone please help me with this?
Jaime Hernandez
  • 2,351 Answers
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it.
I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
Posted on Sep 30, 2022
Sony xbr lcd flicker double picture
I'm a 100% certain your LCD panel is bad, I've run across a lot of Sony/Samsung's with the same problem. It can be fixed but involves taking the TV apart. I have 5 flat screens in my home, 3 of them had the same problem yours had, I patched them and they are working fine! A replacement panel will cost more than a new TV set so that's not an option. If you do no wish to fix, I would suggest putting it on Craigslist as a parts unit, someone will buy it. If I have been a help to you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Sony tv problems
xbr 65x 850b sony ultra 4k tv smart ... what cause it to be black screen but you can hear the show playing
Sony BRAVIA XBR KDL-46XBR4 HDTV LCD Television
you need to replace defective capacitors in the power supply of the tv
1helpful
I have a 46 inch Sony Bravia 46 XBR4 set. The right side went out only colored lines appear. The rest of the screen is fine. email address [email protected]
Sounds like the tcon (timing control) board. Sometimes unplugging the LVDS cables from the tcon, cleaning and reconnecting solves this. The catches on the LVDS cables are easily damaged and must be handled carefully.
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
I have a sony bravia 46 inch flat screen that gets blury on the right side and has horizantal lines. After fooling with it , it comes back.
had what sounds like the same problem. we had the protection plan and called for assistance. he advised us to unplug the tv for 1 minute. when we plugged back in, problem seemed solved. he could not explain why other than to check online with sony for more technical info about this remedy. stay tunned for whether it was a temporary fix......
3helpful
BRAVIA - Information bar on top of screen won't go away
You can turn off the information display using the user menus.
also hitting the display button should make any and all OSD information go away.
18helpful
Sony Bravia 40inch how do I remove input icon
Press " i " (info) button on TV remote and on-screen display will disappear.
3helpful
I can't get rid of the information bar across the top of my TV
Press " i " (information) button on TV remote and on-screen display will disappear.
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
Top Sony Televison & Video Experts
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
