Washing Machines Logo
M
Maxinz Posted on Sep 29, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Older Top load Amana washer LW8303W2 Pumps water out during first 15 seconds of wash cycle, stops and refills the tub, washes 15 seconds, and is pumping water out during the 15 seconds. repeats this over and over, never completes the cycle. I checked the tub pressure switch, its working, and the timer is advancing
Roger R
Level 3:
  • Amana Master 2,005 Answers
  • Posted on Sep 30, 2022
Roger R
Amana Master
Level 3:
Answers
2005
Questions
0
Helped
166688
Points
6474
Please use other modes to check if the issue exists. Unplug your machine for 5 minutes, plug back in and then you can retest the washer. Thank you.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
1helpful
3answers
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
I have an Amana washer model NAV3330EWW purchased in November 2004. The washer will not drain during any of the cycles, It apparently went through the entire wash without draining after the wash or...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Amana washer tub rotates counterclockwise during wash cycle.
The washer has a transmission.why are you openning the top it's a safety.the transmission may need to be replaced,You may be better off getting a new or new used washer,the transmissin is very expensive
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
1helpful
Washer
sounds like the water isnt shutting off once it starts washing,check the valve assy or may have a timer fault,try turning off the taps once it starts washing and see what happens if it starts pumping then timer?
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
