Dishwashers Logo
Question about Dishwashers
How do you take the kitchen door off the 660 prima integrated dishwasher
Can't open door of my cata slimline dishwasher
https://www.youtube.com/watch?v=VE2FY_U7_qY
https://www.youtube.com/watch?v=66oEZE4P9IU
It is normal for a dishwasher door without a kitchen door fitted not to remain open. It will be closed again by the springs on the hinges. If the dishwasher is integrated and no kitchen door is attached, it will not be possible to test the door.
https://www.electrolux.co.uk/support/support-articles/dishwashing/dishwashers/dishwasher-door-will-not-stay-open/
May 05, 2020 • Dishwashers
My Prima LPR660 will not start even though all the lights are on
It is likely the door latch microswitch is faulty and preventing the controller from confirming if the door is shut or not. Or it is possible the door latch mechanism is preventing door from shutting. It looks like this.
Prima Door Interlock
Jan 08, 2014 • Dishwashers
1helpful
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
2answers
CDA CW497 Integrated Dishwasher. Please advise how to connect the door as I do not have the installation manual and have changed all my kitchen doors, but now cannot get the door on the dishwasher.
Hi
Thanks for using FixYa. Please click on this link to download the installation instructions for your Dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 • Dishwashers
6helpful
2answers
How do I take the intergrated door of a busted whirlpool ADG 7540
open the door and inside you will see some screws, some of these screws hold the dishwasher door together and some (about 4) hold the integrated kitchen unit door on, trial and error
19helpful
2answers
Fitting a new front panel to the NEFF 54432 integrated dishwasher
My Neff integrated dishwasher has two holding screws in the top corners and then two hidden screms half way down the side behind plastic covers. Loosen these side screws, remove the top two corner screws and then the door cover/panel should lift out of two lugs at the bottom.
SA 660 SMEG dishwasher constantly filling....
this can be water draining from your sink into the dishwasher via the drain pipe, assuming the drain pipe goes to a spigot on the sink trap.
take the drain hose up as high as possible in a swan neck to prevent this.
Jul 17, 2008 • Dishwashers
4helpful
2answers
Prima lpr 600 dishwahser
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No Heat Dry" button for 4 seconds (or more.  I'd suggest trying this on yours...
Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Top Dishwashers Experts
Marvin
Marvin
mark warfield
mark warfield
