Washing Machines Logo
Question about Maytag Washing Machines
Water over flow from chlorine dispenser
Maytag Bravo XL top loading Water overflowing from chlorine dispenser. Look like the water pressure is higher than it use to. I did cleaned the machine twice this weekend. Then the problem appeared this morning. -I did test the chlorine reservoir by fillingn it manually. The reservoir do empty as it used to. -I removed the chlorine dispenser and cleaned it. Nothing seem too be cloged Any idea what could be faulty? Martin P.S. excuse my english
Posted by Martin Theriault on
Why does my Drain pipe over flow ?
undersized drain pipe will cause this problem
1helpful
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
1helpful
2answers
My Maytag bravo is leaking out of the rear left side, any ideas?
I think I'd be checking the dispenser in the left rear for a crack or rub mark. Also the hoses going to and from the dispenser. They are plastic and fragile.if the top has been lifted or an extremely
off balance load ,one may be damaged.
4helpful
Timed bleach dispeners
You could have a number of things that could cause this problem. Most likely it will be one of 2. The first and most likely is the water valve. This machine has a series of water inlet valves and the one that activates the bleach water could be bad or just have a wire off. Second, you could have a bad timer. If the tube coming from the dispenser was stopped up then you would have an over flow from the dispenser.
3helpful
2answers
Water overflowing from dispenser, no error codes
check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
2answers
MAYTAG front load Washer MAF1300AAW Water is coming out of detergent dispenser and flooding my laundry. I have tried both powdwr and liquid detergent, the same happens???
ck for blockage on inside of tub where water enters any kind of blockage there (lumpy undisolved dry detergent ,socks etc) can cause blockage and water to back up into dispenser and overflow
Leaking water from the Liquid chlorine bleach dispenser
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
11helpful
4answers
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Water overflow
when u replaced the sensor was it the round one that has a clear pipe going to it if ti wasnt u will need to replace it if it was then take the clear pipe off and blow down the pipe this will reset the wayer pressure sensor and should stop the washer from overflowing m8
Top Maytag Washing Machines Experts
Steve
nu267
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
