Question about The Audio Players & Recorders
I have HCD - RV50 i attached Bluetooth & usb every thing is ok but i cant get the volume (low volume) as its displays on front pannel
I think it might be muted to 30 or some % or it not getting enough input voltage help me ...
Posted by Shawn Andrew on
How do i get the pairing code for my lexmark s305
1 Insert a Bluetooth USB adapter into the USB port.
Bluetooth Dongle Connected appears on the display.
Note: A Bluetooth adapter is not included with the printer.
2 From the printer control panel, press Setup.
3 Press the up or down arrow button to scroll to Bluetooth Setup, and then press OK.
4 Press the up or down arrow button to scroll to Security Level, and then press OK.
5 Press the up or down arrow button to select the security level, and then press OK.
• Select Low to allow Bluetooth devices to connect and send print jobs to your printer without requiring users to enter a pass key.
• Select High to require users to enter a four-digit numeric pass key on the Bluetooth device before connecting and sending print jobs to the printer.
6 The Bluetooth Pass Key menu opens on the operator panel display if you set the security level to High. Use the keypad to enter your four-digit pass key, and then press OK.
Locate pairing code for lexmark impact s305
Where is pairing code
1helpful
Want to pair Pro 705 via Bluetooth with Nokia E72. Cell asks for passcode. Have tried 0000 and 1234. Doesn't work
2helpful
How to connect front usb to motherboard
First need to check front usb cable attached on mother board usb plug or not if its not attached so plug in to this pannel and then after you can access it.
1helpful
2answers
How do i activate the bluetooth on my laptop
first thing..i want to know which model of you laptop? is there any bluetooth built-in? if there is...try this....
there a bluetooth key button down in your laptop,you switch it on..i think you know the logo of bluetooth...i think so....
if not a key botton,try to press Fn+ bluetooth key in your keyboard.
I am trying to setup my bluetooth headphones and they did not come with instructions. I just need to know how to put them into discovery mode.
I bought one myself, I have a Vista OS, non-integrated bluetooth laptop.. I had to pop in the USB dongle for capabilities....Still cant get the Mic to work though...so if anyone knows anything on that....I went to HP live chat session too.
BUT HERES THE MODES YOU MAY NEED TO PUT IT IN...
Searchable/Discovery- Hold down the power button about 6-7 secs and it will sound a few short low beeps and flash between Red and Blue, then search 8)
Erase Pairing Profiles- Press and hold the Track forward/track backward Button together until it flashes purple.
Hardware reset- if headset is screwy, froze up, LED display is incorrect...Plug in headset, and hold down bothh Volume buttons, this will power it down and reset its state of confusion, lol
Passkey is always '0000' by default
2-short Hi beeps....Connected
2- short low beeps....pairing mode also
1 long Hi beep.....Power On/Off
1 long low beep....lost Connection
Hope that helps... merry christmas
11helpful
5answers
Cant turn up volume my compaq presario laptop
Ok it could be a few things, I am assuming that you are using XP and its a laptop, so lets try these:
  1. Can you turn up the volume by using Control Panel -- Sounds and Audio Devices --- Device Volume slider?
  2. On some Compaqs, the controls for audio are activated by holding down the FUNCTION key (usually blue letters on key on the left side of keyboard) and then pressing the audio up or audio down key. These keys are usally towards the top of the keyboard. These keys can do multiple things depending if the blue function key is press down first. They can control things like switching between internal and external displays, turning up/down the brightness on your laptop display and controling your audio levels too.
  3. Do you hear any sounds at all, if not, does Device Manager list your sound device?
  4. If this is a desktop PC, number 2 does not apply.
ok try those and let me know, Thx! =)
3helpful
2answers
LG enV VX9900
I would suggest returning the phone to verizon for replacement, if you are still under the 1 year warranty you should have no problems with a replacement.
Top The Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
