Question about Ricoh Office Equipment & Supplies
Ricoh 201 Developer's Magnet is not sticking toner..
Posted by ZAHEER TV (Z TV) on
Solve error code sc360 aficio mp4000
When you replace developer, make sure to clean the waste toner path on the PCU. Waste toner in combination with new developer causes trouble. After replacement of the developer use a piece of paper to block waste toner from falling into the DV-Unit. Then run SP2-801 and do process control.
Then make 100 copies and after that remove the piece of paper. A Ricoh tech told me that the amount of toner in the developer can be very high, so he always made 100 copies before removing the piece of paper. I'm doing this for a long time and I never had trouble with SC's related to TD-sensor.
How to empty ricoh mp171 waste toner
Ricoh MP171 does not have a waste toner container. It recycles used toner back in the developer unit - where it is mixed with new toner and developer powder, and can be used for printing again.
Loud toner error
The machine does not use the toner directly from the bottle, it goes thorught a developer chamber filled with developer powder. Then the toner is charged and can "jump" over to the latent image of the drum.
In this developer chamber, there are some small gears (2-3 tiny gears) that may be worn out. Some developer may have entered the "gearbox", and the deveoper powder is very abrasive.
The teeth of the gears will eventually stop to contact and mesh up. The internal parts of the developer changer stops to revolve, and there is no toner mixed with the developer.
You can see that there is a build up of toner, but it does not enter the developer unit. These gears have to be replaced, and I allways change the developer powder at the same time.
mp 2000 developer gears-2rhlv5r3sdqqpeuzs0ozcjtp-5-0.jpg These gears must be replaced it they are worn. The image shows a brand new part that contains the gears.
mp2000 developer toner input side-2rhlv5r3sdqqpeuzs0ozcjtp-5-1.jpg This is the side of the developer unit where toner enters the developer unit. With defective gears, the developer unit can not pull toner inside of the unit, and the toner builds up in front of the unit.
The gears are cheap, but will often result in the need of new developer powder - and that is expensive.
If print quality does not have to be too good, one can use the old powder and save money. Some of the powder is lost during use, and leaks. There may be some dust in the developer too.
In order to get high quality several parts may need to be replaced.
It is quick and easy to change these gears, just a bit dirty job.
2helpful
2answers
How do i fix problem Add Toner
The Ricoh has toner and developer. When the developer is depleted it can not get to the right density when toner is added so the machine keeps saying to add toner. You need to clean out the developer unit and put in new developer. Depending upon your model you may need to install a drum and blade too. Ricoh technicians are trained to dissemble the unit and just replace the parts needed instead of getting a whole drum/developer unit. If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer and copier maintenance repairs, leasing and supplies.
Ricoh afficio 1045 & ricoh 450 toner is mixed in ricoh fw 780 now background and negative image is coming what can i do plz give some idea
firstly you need to remove the developer and vacume the developer unit and magnetic developer roller.
Put in new developer and correct toner in toner unit.
Call service...
After replacement there is a sequence wich needs to be done, for developer initialization.
10helpful
2answers
Adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
1helpful
How to calibrate the dv and toner...
Did you use a vaccum on the developer unit???? You may have blown out the ATDC sensor on the developping unit
4helpful
3answers
RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
1helpful
2answers
Ricoh 1035 Display Messages
Empty waste toner in transfer unit on the right side door.
5answers
AP3800c Ricoh - Service Manual Needed please.
Look on eBay. There's someone called manualplace selling the service manuals on CD-ROM.
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
