Dodge 2008 Grand Caravan SE Logo
Question about Dodge 2008 Grand Caravan SE
2008 dodge grand caravan se 3.3l v6 timing cover secuency volts, i have missing volts
Posted by Alberto Roland on
  • Larry Ng
    Larry Ng Sep 28, 2022
    secuency ??? what does this word mean.
    please re-type it.
    my wild wild wild guess, cam sensor dead/
    or crank sensor.
    engine dead
    no spark?
    tell all evidence of how you got to
    secuency
Temperature sensor for 2003 Dodge Caravan 3.8 L
Yes no problem.
Engine Coolant Temperature Sensor Fit For Chrysler Voyager ...
https://www.ebay.com > ... > Sensors
Nunmber 0015427418 Parkig Sensor PDC For Mercedes W203 W209 W210 W211 W220 W163 ... 1998-00 Dodge Grand Caravan Coolant Temperature Sensor V6 3.8L
Coolant Water Temperature Sensor for 2001-07 Dodge Grand ...
https://www.ebay.com > ... > Cooling Systems > Other
2001-2007 Dodge Caravan 2.4L 3.3L. 2001-2007 Dodge Grand Caravan 3.3L 3.8L. 2008 Dodge Avenger 3.5L. 2004-2007 Dodge Durango 5.7L. 2001-2004 Dodge Intrepid ...
Rating: 5 · ‎4 reviews · ‎US$9.10 · ‎In stock
Missing: 203 ‎' Must include: 203
Temperature Gauge Question ' The Chrysler Minivan Fan ...
https://www.chryslerminivan.net > threads > temperatur...
Oct. 4, 2015 - Where should the temp gauge needle be at operating temp? 1/4 from bottom? ... 2002 Grand Caravan ES 3.8L. Joined Jun 15, 2007.
thermostat Dodge Caravan - Amazon.com
https://www.amazon.com > thermostat-Dodge-Caravan
Results 1 - 16 of 550 - Engine Coolant Thermostat Housing Water Outlet Replacement for Dodge Grand Caravan Chrysler Town & Country Pacifica.
Dodge Grand Caravan Thermostat ' Advance Auto Parts
https://shop.advanceautoparts.com > ... > Thermostats
Low prices on Thermostat for your Dodge Grand Caravan at Advance Auto Parts. Find aftermarket and OEM parts online or at a local store near you.
Misfire on #5 cyl
2005 Dodge Grand Caravan 3.8L engine misfire on cylinder 5.
answers.edmunds.com > Edmunds Answers
Aug 14, 2012 - MIL on; cylinder 5 misfire; most noticeable at idle in gear ... This could be caused by an EGR valve that is sticking partly open and not closing ...
OBD-II Trouble Code: P0305 Cylinder 5 Five Misfire Detected
www.obd-codes.com/p0305
A P0305 code means that the the car's computer has detected that one of the engine'scylinders is not firing properly. In this case it's cylinder #5.
ODB Code P0305- Misfire in #5 Cylinder - 2008 Dodge ...
repairpal.com > ... > Grand Caravan > 2008 Dodge Grand Caravan
Feb 22, 2011 - ... do something with a misfire in the #5 cylinder of my V6 4.0L engine. ... ODB Code P0305- Misfire in #5 Cylinder on 2008 Dodge Grand Caravan .... My2005 dodge grand caravan jerks when it shifts into gear what could it be.
My Dodge Grand Caravan has a Cylinder 5 Misfire,? ' Yahoo An
How to replace the lens cover on 2012 dodge caravan
Go to any Dodge dealer.
They should identify the part-number, sell it to you, *AND* then install it for *FREE* -- just watch what they do, for the next time.
95 Grand Caravan se. Serpentine belt keeps coming off.
When did this first begin to happen? Changed belt or installed different pulley? Chased same problem. Solved it by shimming the idler pulley out so that belt ran in the middle of the pulley. Check the wear marks on the pulleys to see if the belts are running to the outside.
The front a/c blower does not work, all fuses are good. please help
J, I am sending you some info to read but it appears that the most likely cause is the blower motor relay. Give the following notes a read and if you need some more help give me a buzz... Best of Luck..
1996 Chrysler Town & Country 3.3L, Vin R 1996 Dodge Grand Caravan ES 3.8L, Vin L 1996 Chrysler Town & Country LX 3.3L, Vin R 1996 Dodge Grand Caravan LE 3.8L, Vin L 1996 Dodge Caravan LE 3.8L, Vin L 1996 Dodge Grand Caravan SE 3.3L, GAS, Vin R, Eng Cfg V6 1996 Dodge Caravan Sport 3.3L 1996 Plymouth Grand Voyager SE 3.3L, GAS, Vin R, Eng Cfg V6 1996 Dodge Grand Caravan ES 3.3L, Vin R 1996 Plymouth Voyager Rallye 3.3L Customer Concern: Front blower does not work; no power to it. Fuse is OK. Tests/Procedures: 1. At the blower motor, there is a Dark Blue wire. This wire should have battery voltage whenever the key is in the "on" position. Power for the blower motor comes from the blower relay.
2. Access the front blower relay, it is located on the driver's side under the dash, near the junction block. There will be four wires going to it. The Dark Green wire should have battery voltage all the time. The Dark Blue wire is going to the motor. The Black/Orange wire should have battery voltage with the key in the "on" position. The Black wire should be grounded at all times. On this circuit, the relay is energized whenever the key is in the "on" position. Potential Causes: Front Blower Relay
Front Blower Relay Wiring
Heater Ventilation Air Conditioner (HVAC) Control Head
Tech Tips: The front blower relay is located under the dash, on the driver's side. It may be necessary to remove the junction block (fuse and relay box) in order to see it. Diagnostic Codes: None
2001 dodge caravan 3,3L
I was working for a company that used 1995 Caravan's for their sales force and I do not know of any sensor. I am confused by the term "cover".
Do you mean valve cover? If so does the sensor go somewhere? I can solve your problem, but I need move info. Please call or email me.
Either,way let me know the outcome. Your feed back is my only reward. Also, please rank my answer with as many thumbs as you think I should get.
TomE(414-475-5968)
2helpful
Top Dodge Computers & Internet Experts
Marvin
Marvin
Steve
john h
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
