Question about The Audio Players & Recorders
Is there anyone out there that can help with my Rock ola 490, ( please! )
Now here's the problem, I repaired the mechanism and it works fine but then it stops after the record is placed on the turntable I can trip it and the needle arm go over but there's no sound. (jukebox Fan)
Posted by Mr. Gary Parker on
Rock ola 461 princess consol is dragging sounds like it’s in 33 instead of 45
https://www.jukeboxmanuals.com/rock-ola.html
The turntable is not rotating at 45 revolutions per minute.
could be belt slipping or some other mechanical problem. you may be able to get a service manual PDF download at the above link.
1helpful
2answers
Rock-ola 448 jukebox skipping how to repair
The stylus might be worn or of the wrong type. A simple tone arm needs a round stylus and if an elliptical type (intended for a long S-shaped tone arm) has been fitted by mistake it could skip.
If nothing is wrong there, the remaining conclusion is either the mechanism is maladjusted or the tonearm bearing has a tight spot. In that case the tone arm should be removed and the shaft examined under strong magnification and any irregularities carefully removed, eased, blended in using a very fine abrasive (12,000 - 20,000 grit) and then ensuring the shaft and bearing is thoroughly clean apply a little very light machine oil and reassemble and readjust the playing weight...
Need to turn the volume up on my rock ola model 7000 2bx
This is a link for contact info....
http://www.rock-ola.com/Pages/contactus.aspx
1helpful
CAn I hook up externa speakers for the jute box Rock Ola 480
That depends if you have skp out or a head phone jack .If so the RCA out jack would
have to go to the input of your amp.
or the head phone jack could directley
drive a small set speakers , the 1/4 or 1/8
head phone jack plug wire from a old
pair of head phones would be strip and
wired to small external spk , or driectly
to the auido amp But keep the volume
on the Rock Ola very low if you
chose the latter ,as not to over drive
your amp.
for spicifics
Top The Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
