Computers & Internet Logo
Question about The Computers & Internet
What if if dos noting but shows on the display servive 72
Posted by Burke Benvin on
Error 72
The error message "engine firmware" code 72 is showing up on the display. I've turned the printer off/on and error message still appears.
1helpful
Lines ring to a certain group and I need to change a phone from group 73 to group 72 - how can I do this?
From Ext 10 or 11>
Dial feature 00>
Hit the left intercom button twice>
The display will show "System Programming"
To remove the Ext. from group 73
Dial #502>
The display will show 'Group"
Dial 3 for group 73
The display will show "Extension"
Dial the Ext # of the phone that needs to changed
Dial 2 to un-assign the Ext from Group 73
To add the Ext. to group 72
Dial #502>
Dial 2 for group 72
Dial 1 to assign the Ext to Group 72
Dial Feature 00 to exit System Programming and save the changes
Be sure to ask me if you need more information
14helpful
How do i reset my pioneer vsx 919 ah amp reciever back to its original settings
In the manual, page 72
Resetting the system
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel
controls to do this. Set MULTI-ZONE to OFF.
• Disconnect the iPod and USB memory device from the receiver beforehand.
1 Switch the receiver into standby.
2 While holding down ENTER on the front panel, press ?µ STANDBY/ON.
The display shows RESET < NO >.
3 Select 'RESET' using PRESET +/-, then press ENTER on the front panel.
The display shows RESET? OK.
4 Press ENTER to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
• Note that all settings will be saved, even if the receiver is unplugged.
4helpful
2answers
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
Resolution changes with photoshop while using DMC FZ5
PSE is giving you the screen resoultion which is always 72 no matter what camera you use, it has noting to do the the overall image resolution.
2helpful
2answers
Run dos command through vb 6.0 without showing it
visual basic, on windows, right? jumping to dos, implies a command line, no? how else would you access a command line interface, if not through cmd?
MS-Dos prompt in Windows 2000 & Xp
u can just press alt + enter when u r running ms dos prompt in xp or 2000, it will show u full screen and u once again press alt + enter it will back to normal mode when u come out u just type exit from the command prompt
2answers
Sony SLV-SE820 VHS VCR
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
2answers
Powershot s31s
after 3 months the camera powers off while zooming out.
Has anyone a support servive # for Canon?
Top The Computers & Internet Experts
vince
NADARK
NADARK
A Kisling
A Kisling
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
