Question about Marantz Audio Players & Recorders
Marantz sr18 sound goes out
The sound on my SR18 goes out. I hear a click then it goes out. If I tap it then it will click and sound comes back on. The click sound is the same one that when you first turn the stereo on it will check for any shorts then will click and come on. Do you know what the part is called it sounds like it is going bad.
Posted by mteeitup on
Larry Ng
    Top Expert:
  • Marantz Master
  • 13,319 Answers
NOT A CAR/TRUCK SO MOVED TO AVR
THE AVG. AVR HAS OVERLOAD DETECTOR AND LAMP AND RELAY
THAT FAILS WHEN OVERLOADED.
PER THIS SIMPLE LIST
  1. SPEAKER WIRES SHORTED.ENDTO END
  2. SPEAKER SHORTED.
  3. TOO MANY SPEAKERS WIRED IN PARALLEL.(THE ohms rule violated)]
  4. the amps side is failing.
  5. the overload detector is bad, telling lies, and shutting it down.
  6. try no speakers, to see if it trips.
  7. It is 1999 and is old. even bad caps inside now.
only does
Digital inputs: coaxial, optical
Video Connections: component, composite, SVHS
the rig has fan sensor failure and over temp too, and the service manual covers that.
see protector DRIVE here, it shuts down all outputs via relays.
free to read and DL.
https://www.manualslib.com/manual/1066247/Marantz-Sr-18-U.html?page=6#manual
Posted on Nov 02, 2022
No spark from the distributor in the sr18 engine
Could be any number of things: ECM fuse blown, camshaft/crankshaft sensor bad, low power on battery, bad coil/coil pack. I would really help if you put the year and make of the vehicle, I don't know what an sr18 is.
91 primera sr18 Di,have fixed vacume leak's in inletmainfold,replaced the airflow meter,have got it running excellently but after it has been running for awhile,it randomly dies and wont start again f
I had a similar problem. Nissan sr18di engine. car would run fine and randomly engine would cut off and only start after 20 minutes. Changed distributer
fine since
My engine stalls (not all the time) when coming to a stop after driving in my 1993 nissan bluebird sr18 5 speed
It could be one of the following, clogged fuel injector,
Defective Mass airflow sensor.. .this would be the first thing i would check..
Is your check engine light on, this would help me better to diagnose your problem.
How do i dump midi user patterns from alesis sr 16 to alesis sr18 drum machine thru midi cable
you may well have to go via a third unit, a computer or laptop to store the data then send it back to the other machine.
2helpful
No sound on SR18
One of your five amplifiers has blown its output transistors. Unfortuately, with SR18s, many components down the line from the outputs get fried as well, and (in my experience, anyway) it usually takes hours to track down all the problems. You can still use the unit as a preamp/tuner/surround processor by taking signal out at the pre-out jacks (you have to remove the five jumpers), and feeding it into external power amps, but repairs to the SR18's amp are probably going to be costly and complex. Sorry about the crummy news - hopefully I'm wrong!
3answers
Marantz part for SR18
www.futurlec.com
0.20 US each
Marantz SR18
Buy the part from Marantz.
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
