Microwave Ovens Logo
Question about Sharp Microwave Ovens
My sharp Double Grill & Oven R795 will not heat up to temperature, when used as an oven . Microwave side is ok, can any body help
Posted by George Bochniak on
Manual for R-888B Double Grill Convection Microwave Oven
Did you check the Sharp web site? They usually have manuals that you can download.
How to use SHARP MICROWAVE OVEN model no. R888B
Hi, I own sharp microwave oven model R-888B.
I need user manual..can you help me by sending the same pl
thanks and regards
Selvam
email: [email protected]
Sharp convection microwave temperature is off on the convection side.
this is the thermistor is time to replace,if the fan of the oven is working,also couse this problem.
1helpful
R771 sharp double oven and grill manual needed
Downloadable PDA of manual for this product available here:http://microwave-oven.diplo-best.com/review/SHARP/R-771
Hope this helps.
Sharp carousel convection/grill/microwave maybe R990
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
1helpful
Sharp microwave grill and oven working ok, microwave option not
the magnatron is burnt out they are very expensive to replqace thus i would suggest bying a new microwave
1helpful
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
1helpful
Emerson Microwave Oven and Grill
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
Where can i find instructions for sharpe double grill & oven micr
Info on ordering Sharp UK parts / spares is here.
Emerson Microwave Oven and Grill MWG9111SL
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kgjlkglj
Top Sharp Microwave Ovens Experts
Jaime Hernandez
nu267
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
