Lands Phones Logo
Question about Panasonic Lands Phones
How to set call forwarding on Panasonic KX-TSC960CID telephone set?
How to forward all calls on KX-TG6702
The KX-TG6702 is a standard POST 2-line landline cordless telephone system. You can transfer a specific call between handsets using the Intercom without changing the line that the call came in on. Then you can use the second line for other calls, if the wiring and phone subscription is set up for that. However, if you want to forward any call to another phone number, you will need to connect your telephone provider and set up call forwarding. Follow the directions from the provider to use the service.
The manual for the KX-TG6702 is available on the product support page: http://shop.panasonic.com/support-only/KX-TG6702B.html . The direct link to the manual is currently ftp://ftp.panasonic.com/telephone/om/kx-tg6700_en_om.pdf .
I wish that I had better news for you.
Phone rings once and gets forwarded
Hello there,
Call forwarding is a feature of PABX and Public Exchange systems so do you mean the phone rings once and then 'forwards' to another different telephone number ? If so, then you need to contact the company / person controlling your Lines as you cannot change this on your phone.
If you mean that the phone rings once and then goes on to Answerphone, then this is down to the setting of 'ring count' which is on page 40 of your user manual downloadable here http://www.manualslib.com/manual/117136/Panasonic-Kx-Tg2431.html
If this doesnt answer your question, these please ask again and try and give us more information to help you.
2answers
Call forwarding
Assuming your telephone service provider offers the call forwarding service, yes. The procedure varies from company to company, but often you dial *72 from the landline, then the number to which you want the calls forwarded. That phone will then ring, and you must answer the call to confirm. To cancel the call forwarding, dial *73 from the landline.
If this doesn't work, contact your telephone service provider for their instructions regarding call forwarding.
Want to know how we can divert our Panasonic KX-T7730 to a mobile number
What you want to do is to activate the call forwarding feature offered by your phone company. Different phone companies have different procedures. With many companies you dial *72 then at the second dial tone dial the number to forward to. This number has to answer the call to activate call forwarding.For precise instructions please contact your telephone company.
How do i stop the panasonic KX-TGA641 from rolling calls to my cell phone
You apparently have call-forwarding activated. The exact procedure for deactivating it may vary by company, but in most cases you simply dial *73 on your phone (the Panasonic, not your cell). Contact your telephone company (the landline) for exact instructions.
I have a Panasonic KX-T2355 telephone. How do I cancel call-forwarding?
Since the phone is just an instrument, you'd cancel CF the same as you would do if you had a 2500 plain phone on the line. Try 73# or *73 or consult with the dial tone provider for Call Forward Cancel instructions.
Carl
Have a panasonic KX-TG6500 phone. I would like to know how to use call forwarding feature
Call forwarding isn't a "feature" on a telephone. You have call transfer to another handset, probably described in your manual, or Central Office call forwarding, the standard CF that works without the TG6500. You set that by following the CF instructions provided by your dial tone provider, usually a sequence that starts with 72#.
Carl
1helpful
Answer machine
Panasonic KX7633 is a Key telephone set, it doesnot have answering machine function. whereas you may divert your calls toan analog extn.by call forwarding.
Top Panasonic Lands Phones Experts
Marvin
Marvin
Muzahura Frank
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
