Question about Kyocera Office Equipment & Supplies
I AM USING KYOCERA 3212i . IT SHOWS ERROR "CHECK TONER CONTAINER".I CHECK EVERY THING IS PROPER . STILL GETTING THE SAME ERROR
  • Yousoef
    Yousoef Oct 27, 2022
    Maybe you can try to shake the cartridge toner first, because sometimes we found some case the toner a bit like frozen or lumpy
Yousoef
Maybe you can try to shake the toner first, because sometimes we found some case the toner a bit like frozen or lumpy
Posted on Oct 27, 2022
My kyocera DC 6240 photocopier is showing me refill or replace toner kit even after i have refill it keeps on showing me same thing
you must use OEM toner if you use aftermarket toner that says for use in you will get this problem if you have been using aftermarket toner you will have to change developer or empty all toner from developer unit and start with OEM toner Kyocera stamps their logo into cartridge
I have a kyocera 180 copier does not print texts even when we do internal print. it's blank when copying. We change DRUM, TONNER, DEVELOPER and MOTHER BOARD but still the same. Is there any other thing...
I have a kyocera 181 copier when we switch on the machine it showing error message " shake the toner container' kindly do the needful or send me service manual as soon as possible
I am awaiting for valuable response....
2answers
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
4helpful
Kyocera FS_2020D. Problem is: Call service 7410:0006336
7410 is an error (all numbers following : is the number of pages printed.
- indicating the Drum Unit is not installed properly or you have a defective circuit board. Typically it is drum drum is not fully seated.
If you open the door on the left hand side of the printer, where your waste toner container goes and press firmly on the drum which is located behind the waste toner container and close the printer backup. If the drum is properly seated the error should close.
I hope this is helpful,
Shawn
3helpful
Kyocera FS-2000D shows call service 7410:0130324
- indicating the Drum Unit is not installed properly or you have a defective curcit board. Tyoically it is drum drum is not fully seated.
If you open the door on the left hand side of the printer, where your waste toner container goes and press firmaly on the drum which is loacted behind the waste toner container and close the printer backup. If the drum is properly seated the error should close.
Shawn
Como soluciono el error 7000 que me sale en la kyocera
Code 7000
Contents: Toner motor lock error A motor over-current signal is detected
continuously for 5 seconds since the toner motor is activated.
Causes: Lump of toner inside toner container.
Check procedures/corrective measures: Replace the toner container.
Causes: Defective toner replenishment drive system.
Check procedures/corrective measures: Replace the developer unit
Causes: Defective toner motor.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB
Can you tell me what service call 7002:0006904 on a Kyocera FS 5030N means? Thank you
7002 is the error code; 0006904 is the printer page count.
Error means-
Toner motor 2 overcurrent detection error (cyan toner)
• The engine controller PWB (A0004)
detected the overcurrent of toner
motor 2.
Possable causes-
1. Lump of toner inside cyan toner container or defectiveness of toner replenishment drive system.
Replace the cyan toner container.
2. Defective toner motor 2.
Replace the toner motor 2.
3. Defective engine controller PWB (A0004).
Replace the engine controller PWB (A0004).
1helpful
Missing developer unit
Generally this printer can be separate into 4 major part: Printer body, Toner container, Developer unit and Drum unit. The developer unit is the unit where the toner container "mount" on it and it should be removed to allow cleaning task every time the toner container is replaced.
U may get this error message if the developer unit is not install properly after u replace a new toner container. Just lift the developer unit together with the toner container out of the printer and then insert back properly into the machine.
YBC (/\)
8helpful
3answers
YBC (/\)
6helpful
3answers
Km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
George Mclaughlin
Timothy Van Der...
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
