Ovens Logo
Question about DCS Ovens
I have a dcs wall oven. It's beeping n flashing probe n can't move beyond this. Can anyone help please?
Posted by Chris on
GE oven jgs968s0h4ss Probe flashes and beeping whenever I cook
There's probably a short that makes the range think that the probe is connected. It could be the probe socket or the control board. Check the socket first since it can be damaged more often. See the parts diagram here: https://www.geapplianceparts.com/store/parts/ModelSectionParts/JGS968SH6SS/4/0/0/0/BODY_PARTS . The socket is part 594. It's reached by removing the side panel.
I hope this helps.
Oct 06, 2021 • GE Ovens
Why is there a flashing probe display w/beeping?
Usually this is a problem related to the meat probe jack or the wiring to it. If not the cause, next in line is the control board, part number: 8302346. We can rebuild this board for you. See:
http://www.fixyourboard.com/boards/8302346.html for details and
Fix your board Repair control boards for home appliances for a shipping form.
DCS double oven blinking the word "probe" when no
Check your temp probe ans see if it is not up against the wall or jammed of even broken off.
Feb 24, 2013 • Ovens
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
My probe (PRB) keeps flashing and beeping, how do I make it stop? Thanks!
Hello, Thank You for using FixYa. I will be helping you today.I just had a service call on this issue. If the probe receptacle is clean you may have to replace the control. Try turning off the power for five minutes and see if that works.
Thank You and please rate my answer if it was helpful..
6helpful
2answers
Our oven keeps randomly beeping and flashing F10 on the display. [email protected]
Sorry to read about your problem, I hope this helps you out.
F10
Runaway Temperature.
1. (F10 only) Check RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
2. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
3. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
I Have tried to help you.Please help me and rate/vote my response. Thanks and good luck.
If you live in the Denver Co area I can help.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
2helpful
2answers
Flashes f-3
you have a bad oven temp sensor probe
6helpful
2answers
DCS wall oven F7 ERROR
I TRIED SOLUTION FROM SYMAR DATED MAR 14, 08 IT WORKED FOR NOW. I HOPE IT WILL CONTINUE WORK UNTIL SERVICING...COME MORNING.
Top DCS Ovens Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a DCS Oven Expert? Answer questions, earn points and help others
