Question about Cavs DVD-105G
New Cavs 105G
SCDG Disc takes about 1 to 2 min to load.
This is a brand new machine and on my old 203G the same discs load up in seconds. is there a fix to this problem.
Posted by bwieg on
Anonymous
    New Friend:
  • 3 Answers
I would clean the laser
Posted on Nov 23, 2009
I forgot password for this device. How do I change password?
you prob need to change an IC called an NVRAM i would contact the maker for this service and try to calim it on insurance if you can offset it
No disc
try a disc cleaner before you insert any disc it might be dirty.
2answers
How do I fix the vga output in my cavs 203g Karaoke player
what is wrong with the VGA output? the connector? no display? please clarify
Dvd password? what is it?
if you bought this dvd player new and you or someone else have not changed the parental password, it should be the default password, something like 0000, 1234 or 4321
I have a cavs dvd-105g and when i put a disk in it is says no disk.. what is the problem with this.. it is a new machine,
I also have a cavs machine.......when it does this I open the cassette and reinsert, it usually loads....another idea, open the machine, access the laser, you may have to remove a cover over the laser, and clean it.....also, some models have a software glitch.....so when it does this....shut the power off w the remote.....wait a few seconds, power it back up....and let it load the disc......question, does it do this w all discs?
CAVS DVD-203g remote control
my cavs203g video out put doesnt work and dont have remote
3helpful
While connected via VGA cable Viewsonic VG920 Monitor has an error stating "out of Range" . H. Frequency 157 Khz V. Frequency 59.8 Khz
It was pretty tricky without instructions but trial & error brought me to a successful resolution. This machine comes from the factory set to connect directly to a television with supplied RCA cable. Do that before you connect to a VGA monitor. Using the remote control, press setup and then go into "preferences" and look around for "video" and then to "VGA". Once you click "VGA" the TV screen goes frighteningly blank. The next obvious step is to hook it to the VGA cable and VGA monitor. If your computer is also hooked up and on to the monitor there is no karaoke picture. Shut off or disconnect computer and presto, there it is. <br>
www.texsax.com
1helpful
2answers
Can't see anything on the TV screen
connect you system to a VGA monitor. reste your setting to RCA
2answers
CAVS DVD 105G having trouble reading super CD-G disc
just got the CAVS 105G and the tray will not open.  Could there be a shipping brace that needs to be unfastened in order to open the tray?
Words "roll" on Screen
sir, where did you purchase your player?i think theres a problem with your COLOR SYSTEM SETTING...the color system(REGION NUMBER) of your player must be mATCh with your tv monitor ...TRY TO set it using remote control of your dvd player...and try diff color system setting....post the result.ty eg:NTSC PAL =THESE ARE THE COLOR SYSTEM SECAM
Cavs DVD-105G Logo
Top Cavs Televison & Video Experts
Ekse
Are you a Cavs Televison and Video Expert? Answer questions, earn points and help others
