Refrigerators Logo
Question about Viking Refrigerators
Older Viking fridge/freezer stuck in Sabbath mode?
I have an old Viking 48 inch side-by-side fridge freezer. The lights are off and I "think" it might be in Sabbath mode. I'm pretty sure there is a "hidden" button somewhere, or some random buttons I am supposed to push. I don't have the model number, and my unit doesn't have any "activate controls" button. If I hold on "Display On" for a few seconds, it makes 3 beeps, so I am sure it has something to do with that. Anyone know?
Posted by Nina Dobner on
Ngoro
    Top Expert:
  • Viking Master
  • 3,508 Answers
Posted on Sep 29, 2022
Testimonial: "Thank you so much for trying to help., but mine does not have an "activate controls" button."
Frigidaire Fridge. I finally put it into Sabbath Mode after 6 day of beeping. No one has any idea?
Question edited to add make and taken from your last post.
Sabbath Mode stops various thinks happening, for instance, no more lights coming on and going off, no more adjusting the temperature or putting fast freeze on. The compressor never turns off, it just slows down. All this in observance of the Jewish Sabbath, Saturday.
https://www.frigidaire.com/Owner-Center/FAQs/Refrigerators/how-do-i-set-sabbath-mode-on-my-refrigerator/
The way to fix your buzzing alarm wasn't to engage Sabbath Mode!
What does SAb. Bath mean on an stove clock mean
During the Sabbath, or Shabbat, and religious holidays in Judaism, there may be restrictions on certain activities that can extend to the use of appliances. Restrictions may include turning appliances on or off, using control panels or activating lights and sounds. Sabbath Mode allows people to use their household appliances without violating their religious laws. When appliances are put into Sabbath Mode, certain features may be modified or disabled to accommodate these needs.
Our guide explains how Sabbath Mode affects cooktops, ovens and refrigerators. Keep reading or jump to an appliance category to learn more:
  • What is Sabbath Mode on a stove or cooktop?
  • What is Sabbath Mode on an oven?
  • What is Sabbath Mode on a refrigerator or freezer?
  • What is Sabbath Mode on a wine refrigerator?
You can cook on your stove when it's in Sabbath Mode, but additional features and functionality are disabled. When your stove is in Sabbath Mode:
  • Cooktop burners can still be operated.
  • Sounds such as tones or chimes are disabled.
  • Displays will not indicate temperature changes.
  • Timers are disabled.
  • Cooktop Lockout, a feature that prevents unintended use of the cooktop, is disabled.
  • Energy Save is disabled in select models.
  • Start, Cancel and Off keys, as well as Warming Zone on/off (select models), remain enabled. All other keys are disabled.
When in Sabbath Mode, your oven will disable its automatic shut-off function to stay on longer than 12 hours. This means that the oven will stay in a Bake mode until shut off, which will allow you to use the oven for cooking or warming food. It is important to remember that certain features will need to be enabled or disabled before using Sabbath Mode. This includes the following:
  • Oven Light: Turn your oven light on or off before engaging Sabbath Mode. Your oven light will remain as it was set until Sabbath Mode is turned off - it will not be affected by the Oven Light switch or by opening or closing your oven door.
  • Warming Drawer: If you plan to use your warming drawer, it must be turned on prior to enabling Sabbath Mode. Adjust your warming drawer settings prior to turning on Sabbath Mode, as these settings cannot be changed once the Mode is engaged.
While your oven is in Sabbath Mode, only the Bake setting can be enabled - all other oven settings, including temperature displays, sounds and cleaning cycles, are disabled.
Sabbath Mode allows you to open and close the refrigerator or freezer doors without activating interior lights, sounds or other controls. While your fridge is in Sabbath Mode, water filter status lights are disabled and temperatures cannot be adjusted.
When Sabbath Mode is activated on your wine fridge or wine cooler, the exterior lights and display will be deactivated. This will make your appliance appear as if it is turned off, but your wine cooler will keep running as normal, and its temperature settings will remain unchanged. Learn how to activate Sabbath Mode on your wine refrigerator.
To learn more about Sabbath Mode or for further instructions, refer to your appliance's Use and Care Guide. To download or view your product manual, visit our Manuals and Literature page.
1helpful
2answers
Gfe28 fridge with a sa 66 code when plugged in
GE refrigerators and a lot of new appliances have a mode called sabbath mode or SA 66. it turns off your lights and advanced features for the weekend. To exit sabbath mode push and hold light and lock for 3 seconds, or for some models it's light and alarm for 3 seconds.
2helpful
Inside lights of KitchenAid KSF26C4XYY not illuminate
I bet your fridge was put into Sabbath Mode.
Sabbath Mode is designed for those whose religious observances
require turning off the lights and dispensers.
In Sabbath Mode, the temperature set points remain unchanged,
but the interior and dispenser lights turn off, all sounds and alarms
are disabled, the dispenser display screen backlight turns off, and
the dispenser levers are disabled
To turn on Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds. When the feature
turns on, "Sabbath Mode" will appear on the dispenser
display.
To turn off Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds again.
Frigidaire Gallery side by side error codes
SB is in "Sabbath Mode".
The Sabbath Mode is a feature that disables portions
of the refrigerator and its controls .
Sabbath Mode is turned ON and OFF by pressing
and holding both the freezer "down" and refrigerator "up"
indicators for five (5) seconds. The display shows "Sb"
while in Sabbath mode.
1helpful
Our new 48" Viking side by side does not feed ice cubes adequately. If you need several glasses of cubes it stops feeding and when one opens the freezer door they are piled up and fall all over the floor....
I experienced the same problem several times with our VCSB483DSS also.
What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.
I think the the problems are:
1 - over application of foam insulation in the chute pathway in the door.
2 - possible bad timing on the flap opening causing the falling ice to get stuck.
My solution for the past 6 years:
1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.
2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.
Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
MY viking side by side refrigerator isent working
If only a year old it will be fully covered by warranty. Meantime try disconnecting from the mains power supply for 30mins (dont worry the frozen items wont be affected for this short a period) then switching on again, as this may trigger the motherboard into normal mode
Good luck
Fan keeps running
freezer fan runs when freezer calls for cooling
ref fan runs when fridge calls for cooling
condenser fan up top runs with compressor
lower unit condensate fan runs with compressor
fans should not be noisy
control monitors temp and will give alarm if temp rise
please contact viking as your fridge may have a safety recall on door hinges
2helpful
3answers
Admiral Fridge Freezer
i have solved the problem with lights onthe drinks dispenser itis in sabbath mode torelease it push and hold the lock andauto light buttons at the same time for 3 or 4 seconds it worked for me hope it solves your problem
alan stoker.
2answers
All lights went out in my refrigerator/freezer
I have this side by side Viking- The worst product I ever bought. Nothing but problems. If I can give anyone advise do not buy one.
Top Viking Refrigerators Experts
Jay Finke
Jay Finke
Colin Stickland
Colin Stickland
David Shaub
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
