Lands Phones Logo
Question about NEC Lands Phones
How to use NEC WebPRO to reset voicemail with security code?
I have access to Admin NEC Webpro, but I can't find the section where I can reset the phone's security code for the mailbox. We don't have an admin phone since most of the answers I'm getting are saying to go to the admin phone. 15-XX 15-01- Extension Setup - doesn't have a reset option for mailboxes. 45-XX 45-02 Voice Mail Integration - Doesn't have a reset option. Version of NEC WebPro: WebPro 6.00.00 Thank you
NEC Dterm80 red message light keeps blinking. Need to reset. Belonged to previous employee and do not know pswd. please advise how to reset.
I'm not an NE guru but I work on many others.
You really need an administrator for the Voicemail to reset the password.
Try this.
From an admin phone, enter the voicemail. Then select More, Mgr, ChBox, then enter the ext# you need to reset the password on. Then choose Reset Password (Select Yes when the system asks you if want to reset the password). You can access the reset extension's voicemail by entering the default code (0327).
Good luck.
Try this.
Good luck.
My NEC DVL(XD)Z-Y (BK)phone has a red blinking light for reception button. No one knows the mailbox code since the receptionist was replaced. How do I reset code or stop light from fast flashing red?
These instruction are for a Univerge-SV8100
To Delete a Security code, the greeting, messages or recorded name in a personal voicemail box:
1. From any phone with Admin rights (Usually ext 101)
2. Press the message button
3. Enter security code if there is one
4. Dial 72 to access System Admin
5. Press SUBS soft-key (in display)
6. Dial the extension number you want to change
7. Press the available softkey in the display or 7 to delete the security code.
Be careful when you are in the admin part of the programming because you can really mess up the voice mail if you do something wrong. To check what type of phone system you have look for a NEC box in your phone room or server room. The complete PDF is here
http://www.integratelecom.com/resources/Assets/sv8100-admin-inmail-master-11-5-07.pdf
3answers
How to reset the pass code to get messages
Nec Electra phone reset
1. Login into Voicemail
2. Go to admin Feature
3. Follow the instruction
After that your phone will be reset.
008ce543-db10-480d-b83b-2eba9c70077c.jpg Nec sv8100 IPK DTerm phones Inlinecom
How do you get caller id to show up on phone?
IT NEED TO BE DONE IN WEBPRO WITH THE LAN PORT ON CPU OF SYSTEM . TECH PASSWORD NEEDED. LET ME KNOW
Can't access voicemail. I do not have security code
we can reset the password on the mailbox for a remote charge.
If any has the admin password they can log into the admin box and reset a user id.
[email protected]
Tony
4helpful
3answers
Tengo una lg webpro lic-200 y se me perdio el drivers por favor que hago
Hola, en http://www.mvredes.com/
en la seccion descargas/lg/network/drivers/multimedia tienes los drivers.
El modelo de tu camara es: LIC 300
Espero que te resulte de utilidad
3helpful
Voicemail
From an admin phone, enter the voicemail. Then select More, Mgr, ChBox, then enter the ext# you need to reset the password on. Then choose Reset Password (Select Yes when the system asks you if want to reset the password). You can access the reset extension's voicemail by entering the default code.
NEC 16D-2
You should have a computer somewhere in the building running callexpress that controls the voicemail for each extensiion,
Find the computer and simply go into the configure screen of the extension you need to unlock and change the password to 0000
Top NEC Lands Phones Experts
Muzahura Frank
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
