Ovens Logo
Question about Fisher and Paykel Ovens
I have a fisher & paykel saffron oven and the outside ring on the dual element is not working and I have replaced the simmer states , what could the problem be ?
Fisher and Paykel ceramic muti function saffron stove , the dual inner element is working but not the outer ..what could the problem be ?
Posted by DOUG PILE on
2helpful
How to set clock on saffron stove fisher and paykel
as it shouls calways be off at the wall when not in use, but if you want to then press the two left and the second to last button all at the same time
Hi the hot plates have stopped working on my fisher and paykel oven
there is a seperae fuse for the elements if it is wired as a two phase which mean at your fuse box there is teo oven fuses one of them is blown or tripped
Fisher & paykel b1602cte oven fan in element at back of oven not working
FIRST YOU NEED TO KNOW JUST HOW THE FAN WORKS, DOES IT WORK OFF OF ELECTRICITY OR IS THERE A COMPUTER CHIP IT WORKS OFF OF. DOSE IT WORK OFF OF JUST A SWITCH. LOOK UP ON LINE TO FIND A MANUAL FOR A FISSER & PAYKEL B1602CTE IT MAY TELL YOU WHY IT IS NOT WORKING.
1helpful
The lower oven of my Fisher Paykel B1603ED dual oven is oven is overheating. I carefully replaced the Thermostat with a new and it did not fix the problem. Also when it is set to fan forced it will no
The model number supplied cannot be found on the web site a parts manual can be obtained to provide information on your product.
goto fisherpaykel.com and find the manuals available parts would be best and they may use several ways of regulating the supply . Or an element has blown visual check when cooker is ISOLATED FROM THE MAINS SUPPLY. There usually is a Grey colour round the hole in an heating element, if not sometime a black ring as if too much heat in one spot, test with a continuity tester it should have conduction.
Hope this is helpful
Regards
John
Nov 01, 2014 • Ovens
I have an OR90 Dual fuel range oven. My problem is that the main oven the bottom does not heat up? The top is working fine
check both oven elements are working if ok check thermostat probe inside oven isnot close to or touching any of the elements if all os ok then replace thermostat
Top element not working
either a wire of the element or a faulty element
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Top Fisher and Paykel Ovens Experts
mark warfield
mark warfield
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
