Question about Marantz Audio Players & Recorders
My marantz CR502DAB flashes red only once when it is plugged into the mains, what should i do ?
Posted by Liam Green on
2answers
Marantz ST6006 Receiver. How to fix AV receiver not powering up after sitting idle?
Question edited for clarity and typo.
Check the fuse in the plug (UK). Check power as far as the unit with a proximity tester. Look for a fuse in the back near where the mains cable enters. Open up and look for fuses.
Nice unit
https://serviceandrepair.sellfy.store/p/nbkxai/
https://www.google.com/search?q=marantz+sr6006+service+manual
1helpful
2answers
The red light on my Marantz SR5008 keeps flashing and wont turn on. How can I fix this
Disconnect everything and then plug in only the power. If the light still blinks, the PS is probably damaged and will need to be serviced. If the light doesn't blink, you have a shorted connection. Speaker wires are probably the most likely.
I have sky tv and a marantz system, marantz system flashes pcm dig and tv loose signal intermittently, help
Your Sky box might need a firmware refresh. Switch it off at the mains socket. Press and hold down the BACKUP key on the SKY BOX (not the remote). Switch on at the mains and keep the backup key pressed down until the TV shows an info screen that the box is updating.
Allow the box to complete the cycle.
Try your system again.
What can i do to stop the red light blinking for marantz sr5007?
Turn off the power using X.
2 Press X ON/STANDBY while simultaneously pressing PRESET CH + and PRESET
CH -.
3 Once the display starts flashing at intervals of about 1 second, release the two
buttons
Marantz SR4003 flashing red standby mode
Sir my marantz sr 4003 AV Receiver standby red light blinking last time surround mode and exit button pressed two times problem solved now two days on words again same problem please give me suggestions
How do i attatch preamp to marantz sr9200 for phono
If you are talking about a phono preamp, take the output rca cables from the turntable, "red and white" plug it into the preamp input, "labled" next take a red and white cable wire male ends, "3 to 6" feet long, and plug the one end in the output of the preamp, "labled" and finally plug the remainder into the AUX input of the Marantz receiver matching the colour codes so the left and right channels don't get mixed up, you now should be good to go.
Hi I would like a little help to update the firware dvd blu ray bd 8002 Marantz tell me how should I do? thanks you.
Hello
Enter these sites for fudate your Maranz.
www.buyblurayplayers.com/firmware-updates/how-to-update-your-firmware
www.avforums.com/.../765663-marantz-firmware-updates-sr7002.html - United Kingdom
softwaretopic.informer.com/firmware-update-tool/
I'll ge you some hints also
Open the Internet browser and navigate to the Marantz.com website. Select "Products," then choose "DVD Players."
Select the DVD player you are currently using, then select "Manuals and Downloads." This lists all of the available updates for the Marantz DVD player.
Click the software update to download to your computer system
Plug the USB flash drive into a USB port on the computer, then click "Start," "(My) Computer," then double-click the removable device icon. A window loads with all of the files stored on the flash drive.
Click-and-drag the software update into the open window, then close the window, right-click the removable device icon and select "Eject."
Disconnect the flash drive from the computer once the icon disappears.
Plug the USB flash drive into the USB port on the rear of the Marantz DVD player, then power on the device. The software update will upload onto the DVD player. A prompt on the television screen appears once the update has finished.
The volume will only turn up to "0" and barely hear a sound from the speakers. How can i trouble shoot this
I had a similar problem with an SR4320 that I bought used at Goodwill. First of all, turn the volume knob down; 0 db is actually the highest volume. Not sure why Marantz did that; it's counterintuitive. Set it to a more normal volume like -30 db. If it suddenly starts working, you'll blow out your speakers (and possibly your eardrums).
Second, check the back of the unit. There are two RCA connections that say "Pre Out" and "Main In". This is where you could connect another amplifier or a graphic equalizer. But if you don't have either of those hooked up, you need to have them connected to each other. Apparently the unit shipped with jumpers connecting these plugs, but a prior owner must have taken them off.
All you need is a short (1 foot or less) red and white RCA stereo cable. Connect the top Pre Out to the top Main In plug with the white cable and the bottom Pre Out to the bottom Main In plug with the red cable.
Hope this helps! It's a terrific receiver!
When I plug in my Roomba, it flashes red once...
Poer circuit is dead. THe simplist repair is for you to replace it with a new main board.
1helpful
2answers
Marantz CDR631 is dead
open it up and take the mechanism out, then you should see a servo PCB screwed to the underside of the mechanism.
unscrew this and where the connecting wires plug in from the main PCB, you should see 2 or 3 fuses which look a bit like capacitors and should be red in colour marked MPXXX eg. MP100?
replace these if you can find spares, if not bridge them with a bit of thin wire soldered in place and then it should switch on once reassembled.
the clicking sound you mention will be the main power supply capacitors running and this is normal.
Top Marantz Audio Players & Recorders Experts
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
