Dishwashers Logo
Question about DCS Dishwashers
DCS bottom dish drawer beeps and flashed inside the drawer it will flash * and play buttons?
Dcs bottom dish drawer will flash * and play sign and beep. When I reset it will act like it's going to run but will go through part of a cycle. There is no standing water and free of debris. The arm has nothing stopping it from turning.
Posted by Christa hoesch on
Phone beeping during call
the beping is probably a incoming call try pressing the flash button on you phone
2answers
I have a double drawer fisher and paykel DCS dd-224p model. bottom drawer works fine. top not working
These units are nothing but grief!! Problem sounds similar to my one, it caused me no end of problems from the time it was installed and don\'t bother calling F&P service coz it will cost you almost as much as a new dishwasher. They have an inherent prob with circuit board, even service tech (on the quiet) said they are bad.The best thing I did for mine was throw it on the scrap metal pile and bought myself a Meile, not one problem. its super quiet and designed to last 20 years. Use the bottom one till it completely craps itself (prob not long) and then buy a NON F&P one!!!
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
1helpful
DCS bottom dishwasher drawer u1 code: begins cycle, runs a couple minutes then stops and beeps
Hi there Ypowers, U1 fault code relates to the fill system. Is the tap turned on, is the spray arm position correctly and free to rotate, nothing blocking it?. I hope this helps regards Gary.
DCS over F7 error beeping
KEYPAD BUTTONS ARE REMAINING CLOSED FOR MORE THAN 32 SECONDS. REPLACE KEY PAD,DUE TO STERCHED PANEL MEMBRANE
Samsung dcs with 5 handsets, only one rings, the rest flash
the other handsets were in the wrong huntgroup.
on the handset, onhook, press 53
then choose the group, ie 501, 502, 503
4helpful
2answers
Haywire dishwasher contol panel
did you stand up and salute it properly!!!. just kidding , were you using the d/w when this happened??? either under te sink or sometimes if you pull out the lower drawer youl be able to unplug the unit perhaps had an electrical glitch...if you can pull out lower drawer theres a pretty good trouble shootertaped inside the back wall
Stove beeps
it's the igniter, just had that problem. cost me $70.00 for a service guy to tell me since DCS is no help on the phone.
Top DCS Dishwashers Experts
Marvin
Marvin
mark warfield
mark warfield
Are you a DCS Dishwasher Expert? Answer questions, earn points and help others
