Yamaha 9.9HP and 15HP "S" Series Outboard Motor Shop/Service/Repair Manual Logo
Question about Yamaha 9.9HP and 15HP "S" Series Outboard Motor Shop/Service/Repair Manual
How do I adjust the shift linkage on a 00 Yamaha F15 4-stroke tiller outboard? Adjusted the rod as short as it will allow but still acts like the gears are slightly engaging in neutral.
Also, indicator on shift lever shows it to be in neutral when it is actually in reverse, and forward when it is in neutral.
Posted by Kirk Bell on
25 hp merc outboard motor remote throttle....wont shift at the motor
There is a rod that goes down to the lower leg . It is exposed just under the engine but quickly disappears into the leg. Check to see that it is moving feel and not binding up. Next with the motor off try rotating the prop and then shifting that rod is what actually sifts the linkage in the lower leg to forward and reverse. If you can shift the motor with the cables disconnected from the motor then the cables may need to be adjusted or replaced. Pay attention here... if you adjust the cables and the engine does not attempt to start then you need to readjust. There is a built in kill switch on the shifter that will not allow electricity through to the starter if the neutral position isn't in true neutral position.
Jun 20, 2018 • HP Boating
2answers
Yamaha 40 hp outboard
Look below lower mountings you will see the shift rod with along nut and a lock nut,undo long nut,do this with motor in reverse gear,some 40s have a stainless plate cover which you have to remove first
1helpful
Yamaha grizzly 660 shift linkage adjustment
Will it not go into park or will the light not come on? If it goes into park look at the switch.
Check and make sure there is nothing binding the shift linkage or that the linkage is not bent. If all looks good adjust it.
Adjust your shift linkage just enough for it to go into park. Then check engagement in other positions
How do i replace shift lever on a mercury 6hp 4 stroke
shift lever has a bolt in it and shift rod you need to remove powerhead complete to access also remove gearbox !
Where is the idle screw on a 2000 R1
The following is for a 2001 model, may be the same on a 2000.
Follow your shift linkage from the foot shifter 'up' the linkage rod.
Where the linkage rod meets the shift shaft, right beside it you will find a gold colored Knob.
Thats the idle adjuster.
You will want to loosen the left Mid-fairing to allow you to get your hand behind it to reach the adjuster knob.
You dont have to remove it, just loosen the 1/4 turn screws holding it.
do not adjust the idle when the engines cold. Have it good and warmed up.
When your finished, retighten the 1/4 turn screws, and your finished.
Small adjustments, allowing the engine to 'catch-up' work best.
Good luck.
25 yamaha outboard 2 stroke was popping out of reverse now won't go into reverse !
Good Day To You Neil
Your Gear Linkage Has Been Miss Adjusted !
And It Has Caused The Shift Pin In The Gear Box To Be Worn.
You Will Probablly Have To Take It To A Repair Centre To Be Done For You , You Need Special Tools!
Regards
Gordon
Sep 20, 2013 • Boating
How do i set timing on a 1996 mariner 40 hp 4 cylinder 2 stroke outboard?
timing marks on flywheel and a pointer above the carbs , under the flywheel there is an adjustable rod from the trigger to the throttle linkage ! strobe light required , cant remember timing off top of my head as out so google it !
Top Yamaha Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Yamaha Photography Expert? Answer questions, earn points and help others
