Computers & Internet Logo
Question about NTI Computers & Internet
I am using NTI Backup Now EZ 7 on Windows 10. Where is the 'overwrite old backups' option?
Tesfay
    Passionate:
    Visited the website for 10 consecutive days.
    Novelist:
  • 139 Answers
If you're using NTI Backup Now EZ 7 on Windows 10, you may be wondering where the 'overwrite old backups' option is. Here's a quick guide to help you find it.
Open the NTI Backup Now EZ 7 application. Click on the 'Advanced Options' tab. Click on the 'Backup Options' button. In the 'Backup Options' window, select the 'General' tab.
Under the 'Backup Options' heading, you will see the 'overwrite old backups' option. Select the 'overwrite old backups' option and then click 'OK' to save your changes.
I hope this helps!
Posted on Nov 22, 2022
Runtime error with EZ Backup restore
Did you try to reinstall the EZ software? perhaps you accidentally removed (a part of) a program.
Then try to restor the data again.
I purchased two NTI Backup Now EZ backup drives and have not been able to get either to backup anything off my Sony Vaio E w/Win 7. The system is 500G w/4G RAM.
You will have to contact the company directly. Each system is different enough that you will need their help troubleshooting the issues.
2answers
Can't run NTI Backup software on Windows 7
Have you installed the proper USB 3.0 drivers.
If not install the USB 3.0 drivers that support your motherboard.
My computer won't power on after using backup now ez
when it is not compatible with the configuration of the computer,how can windows 7 be installed! you can reinstall the OS but only try xp if it is not compatible!
I used a Toshiba 1/2 TB external drive with NTI Backup Now EZ software for some years and then the laptop crashed. After byuing a new one the happy moment when all could be restored never appeared. The...
Maybe the restore function only works with the original piece of equipment. Ouch.
You might want to contact the manufacturer of the software to see if they have a fix or solution. Good luck!
I originally downloaded NTI Backup Now EZ software from the Toshiba website to use with an external Toshiba hard drive I purchased and have been running both "File and Folders Backup" and...
Hello bobdurack
I'm not shure this is the solution but it's a possibility : has the letter of your external Toshiba eventually changed ?
Regards ,
fanaudi .
I used the backup now ez to take all my photos, etc off my desktop prior to upgrading from vista to windows 7 and now I cannot get it to restore back to my desktop. HELP!!!
This might be one of those programs that must be installed in order to work. I would imagine that you must install the program and have it do a restore.
Some programs keep a record of the backup on the hard drive. When you upgraded, the record might have been destroyed. If this is true, your backup software will have a utility to rebuild the index of the backup so it will work.
var fctb_tool=null; function FCTB_Init_b57a4ca77bce4177981a716bb3d932c6(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_37914be2a9c340639799c674a792b2dd(t) { fctb_tool=t; start(fctb_tool); }
2helpful
Hi I'll briefly describe my problem I've an external HDD (Toshiba) with NTI Backup Now EZ software installed on it, and I used it to back up my files the problem is that I can't restore my files now...
You might need to get an older version of NTI Backup Now. I had the same issue. I was using Backup Now 4 which saved everything as .nbf.files. I downloaded a trial version of Backup Now 5.5 and tried to restore the files only to find .nbf files are not compatible with version 5.5!
I sent a rather facetious e-mail to NTI moaning about this issue and they sent me a trial version of version 4. If I were you, I'd do the same. http://www.nticorp.com/en/us/product/backup_now5.asp
All my .nbf files are now restored.
Top NTI Computers & Internet Experts
Marvin
Marvin
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
