Washing Machines Logo
Question about Bosch Washing Machines
Bosch Axxxis 500 round plastic piece necessary
Hello. Yep have a Bosch 500 that I am trying to clear the coin collector. There is a round plaster piece the is screwed in preventing access to the drain and coin collector. Is this piece necessary. All the videos I have looked at none have the piece. You need a special tool to remove piece
Posted by Mary Oates on
Plastic shavings on my wet clothes in a Bosch Nexxt 500 plus washer.
It could be that the basket is loose. If you hear a loud noise like metal to metal you have a loose bearing causing the basket to shake and the basket edge touching the plastic tub and shred it you see plastic pieces on clothing
A merchant, beforedying, decided to sell his very valuable coin collection to three coin collectors. The first collector bought half of the coin collection plus half a coin, The second collector bought...
There are an infinite number of solutions to this. However, if you also stipulate that the three collectors between them bought the entire collection then there is only one solution.
There were seven coins to start with. The first collector bought half the collection (three-and-a-half) plus one-half or four coins, leaving three. The second collector bought half the remainder (one-and-a-half) plus one-half or two coins, leaving one. The third collector bought half the remainder (one-half) plus a half or one coin, leaving none.
Bosch 500 series error E13 can't get to the front pump
make sure the machine is unplugged,, turn water hose off and undo it from the machine.. then undo the waste pipe now pull machine out and lay a cushion on the floor at the back of the machine.. lay the machine on the cushion (so its on its back) undo one screw bottom end near pump on plimpth and push plimpth to the right and once off you will see 3 screws around the pump,, undo them and pump should fall down,, now you have the pump in your hands it should unscrew,, take out all the **** from the pump,, once you have cleared everything you should put everything back together.
1helpful
SHE6AF06UC/03 upper wash arm came off. Have arm (d'uh) and round piece that goes thru it. Seems to be another piece that connects arm assembly to top of unit as that round piece can't snap into what is...
Welcome to FixYa.
If you follow this link below and save the file and then open it,( pdf about 5mb in size ) refer to page 21 it will illustrate how the upper arm is attached.
http://cid-674627ce75316bb3.office.live.com/self.aspx/Bosch%20Stuff/DWcompleteguide.pdf
Let me know if that works for you. Good luck.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
4helpful
Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Need clear plastic cover for front of door
I have one. My new Bosch washer came 2 months ago and I removed it immediately.
The problem is that it arrived scratched up somewhat, which is another reason I removed it as this will only get worse with a plastic cover.
The cover also makes it harder to see into the machine while it's in operation.
To be honest, I'm not sure why you would want it on there, but if you really need one then mine is available.
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
5helpful
2answers
Is there a filter that I can clean out located behind the round cover on the lower right front of my Bosch Nexxt 500 series washer?  If so, how do I get the cover off?
just pop it off with a small srewdriver and yes you can get to the fluff filter through the round cover
when you open the filter there will be about two litres of water come out beware
3helpful
4answers
Bosch frontload washer will not drain
Hello Mamma5, It sounds like the drain pump is either seized or jammed. The drain pump has an anti jam device in it. Since you have figured out how to get into the drain pump, try turning the inpeller in the back. It will be a little hard to turn as the magnets in the motor will fight you on this. Look close in case there is anykind of thread wrapped around the inpeller. If so, then you can free the pump. If you cannot free it to run, advise the repairman what you found so he can bring a drain pump with him.
Hope this helps.
Top Bosch Washing Machines Experts
Marvin
Marvin
Steve
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
