Question about The Office Equipment & Supplies
HI IM USING FRONTIER 370 i have error 2102 thats no connection betwwen scanner and printer i change the caple the main board but nothing change whats the solition for that
Posted by Foza on
2answers
Fuji Frontier 370 error w2108 how to fix it
ERROR E-2415, 2418, 2416, 2411 FOR FUJI FRONTIER 370
What is 811 error?
You cannot repair this error easily. Most times its the main board that has the problem but its more than likely to be the scanner pcb than the main board. I am actually in the middle of the very same error and have tried the main board and it is the scanner pcb that is causing this particular problem. As you do not state what model you have , I cannot give you a part number.
1helpful
2answers
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
4helpful
5answers
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
5helpful
5100cn
The exact meaning of this error code ( 006-370 ) is <IOT ROS Motor Failure>. The SOS signal does not come from the ROS ASSEMBLY. What this means is the printhead, also know as Raster Output Scanner - laser unit. failed to generate a "start-of-scan" or SOS signal.
There is a humidity and temperature sensor in this printer that is designed to prevent the laser from being used in extreamly high humidity situations to prevent damage to the printer. This sensor rarely fails, and that is why it is the least likely cause of a true failure.
If in Fact you are in a high humidity situation. There is nothing wrong with the printer, and it will function normally when taken out of the humidity. Possibly running a dehumidifier in these cases will help. If this is not the case and are certain this is not the problem, then a true hardware failure has occured.
There are 3 possible causes for this failure, and they are listed in the most likely to least likely.
1) the ROS Assembly ( printhead, laser unit )
2) the PWBA MCU ( printed wiring board assembly - Machine control unit ).
3) Sensor assembly. ( humidity and temperature sensor )
HP LASERJET 4PLUS PRINTER-PRINT OUT BLANK PAPER AND WITH ERROR MSG 41.3
Get a new printer.
Serious if it is happening repeatedly and it is not because of corrupt data like a bad file being sent to it, then tis biga buckas any way you go, replacing the laser or the Main Control Board. From your description it will be laser, laser units wear out because inside is a little motor working real hard and eventually they wear out or main board the brains behind the operation has lost the plot
here is the code description from manual
41.X Printer Error
A temporary printing error has occurred. The page containing the error will automatically be reprinted. If the error persists:
1. Reseat the connections to the laser scanner and then to the engine controller board.
2. Replace the laser scanner.
3. Replace the engine controller board.
Top The Office Equipment & Supplies Experts
vince
old marine
old marine
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
