Question about Eclipse Audio Players & Recorders
CD player in eclipse radio cd8484 wont do anything
It won't take a cd won't play and it clicks
Posted by Jeffrey Basney on
2helpful
Why do i get format error when i put songs from a cd on the eclipse?
1. Why do i get format error when i put songs from a cd on the eclipse?
= This is probably because the format that your songs are currently in is not supported by your device. Supported devices on the Mach Speed Eclipse 180 MP3 player are: mp3, wav, and wma. If your music is for example filename.cda, it won't be able to play because of the file format being .cda.
2. I also see the song on the eclipse but it says drm protected and will not play the song.
= When ripping your music, check your ripping options in whichever ripping software you are using that protecting music files is off, this may be the reason why your music cannot play - it may be protected to only play on the computer that ripped(recorded or duplicated) the song.
8helpful
3answers
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
2answers
Car batter died, CD player no longer plays.
you either need to find the first cd that was played in it, or call eclipse to see if they can help you. if the radio was stolen, chances are they will not help you.
2helpful
I have a eclipse avn7000 and apparently I put a cd in it that the radio cant read, and it wont let me eject. I can hear the radio trying to read the disk at all times unless power is off. Is there a reset...
There is a reset button just to the right of the CD slot, it looks like a reverse dimple. use a ball point pen and push it in and hold for 3 seconds. when you release it, all the settings will go back to default and you will loose preset stations, however, it should release or play the disc. Hope this helps
1helpful
1helpful
2answers
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
CD Eject
Hello, this is andre tucker I am trying to set my clock on my eclipse car radio and can't seem to do it the model is eclipse 5443
can you halp me?
The CD/clock screen has stopped working...
Go to Best buy- have a new radio installed
1helpful
2answers
Eclipse CD3402
I HAVE A ECLIPSE CD 3402 IT was working but i had to dicunect the baterie and it says call 1800 what can i do
Top Eclipse Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
