Science & Laboratory Logo
Question about Science & Laboratory
TOPCON OSM-610 Electrical Diagram needed
Light source Electrical diagram is needed for repair a vandalized surgical microscope TOPCON OSM-610 Thanks un advance
Posted by Augusto Marcuzzi on
Hi i need a wiring diagram for a BA falcon 2005 dedicated gas can anyone help? Thanks in advance
You should check out www.reliable-store.com they have info on repair, service, wiring diagram, electrical diagram, fuse diagram, troubleshooting, PCV, owner's/service/repair/parts manual, fault codes, error codes, etc everything on all vehicles. must check it out
I have inherited a Nikon 83988 microscope with a transformer. I know nothing about this; I have no manual. I think there may be bits missing (there is no lamp for example). When I plug in the...
I think the number you gave is the microscope serial number, to hope to get help you need to find the model number so people can help. At least post a picture. In general the microscope needs a light source to be bright enough to use. The transformer is meant to provide power to the light. If you use the microscope with a light shining through the object held by a glass slide then the light is below the stage which holds the object. Sometimes on simpler microscopes they have a mirror below the stage and you shine a bright light beam into the mirror and must adjust the angle to reflect the light through the slide. In more complex systems the light is built into the microscope. For opaque objects you must shine the light from above onto the object. If you can't find the official Nikon light source to connect to the transformer, you may be able to get non Nikon light sources. For my stereo microscope for example, I use a LED ring-light I bought on ebay for ~$25. This lights the objects from above and fits around the microscope tube just above the stage.
Need Behringer V-Amp Pro repaired or find diagram & parts
my euro2442 is not prperli runing so plese send me your service center in india
2helpful
2answers
Light on the Vivitar 900x microscope does not function
It's not uncommon for these low end microscopes to have wiring issues right out of the box. My guess is a faulty contact at the switch or at the socket, as these microscopes work on a very simple electrical circuit.
You can try to disassemble the microscope yourself and see if you can find the disconnected wire, shouldn't be too hard. The other options are to send it back to walgreen's and try to exchange it, have it sent back to directly to vivitar for warranty repairs, or have a technician check it for you.
Top Science & Laboratory Experts
Tom Chichester
Don A
Don A
ADMIN Andrew
ADMIN Andrew
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
