Car Audio & Video Logo
Question about Kenwood Car Audio & Video
Kenwood kdc-515 sound stopped
The sound stopped on my kenwood kdc-515s but the face is still lit looks and feels like normal except no sound.
Posted by Julian Jacobs on
Kenwood kdc mp242, no sound, ford explorer, 94
if that ford had premium sound you have either not hooked up the factory amp or you have blown a fuse to it. you won't get sound unless that amp is hooked up.
3helpful
I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
1helpful
2answers
I have a Kenwood KDC MP532U. The face plate will not display.
it more than likely has bad solder connections inside the radio on some surface mount resistors usually located on the right front of the radio as it faces you.
Got a Kenwood KDC-PSW9524. For some reason the
MINE DID A SIMILAR THING THE FACE PLATE IS MOTORIZED AND GOT STUCK CLOSED SO INSTEAD OF BREAKING IT I FOUND THE RESET BUTTON ON THE RADIO IN THE FRONT ON THE SIDE ITS A LITTLE TINY BLACK HOLE STICK SAFETY PIN OR SOMETHING IN IT.BUT BE CAREFUL IF YOU DONT KNOW YOUR RADIOS SECURITY CODE IF NOT SURE WHILE STILL ON GO INTO THE OPTIONS AND TURN THE CODE ACCESS OFF.!
Kenwood KDC-MP922
there is a button under the back of the face in one corner, just press around the back of the face with the car on until you feel the button press in and it should open.
If not you may have a bad ribbon cable that is not too expensive to replace.
2answers
Kenwood kdc 7009 - just bought car w/ stereo in it, but no remote or codes ?
Look for a small hole in the face plate. Take the tip of a pen and try holding it in for a few seconds. Re-setting it should work.....
3helpful
Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Kenwood KDC-519 CD Player
Check ribbon cable from main board to face for breaks in the lines. Replace ribbon cable if bad.
1helpful
2answers
Kenwood KDC-715s problem.
the kenwoods with the motorized face platesdevelop one problem with time. the flexable ribbon cable between the main unit & the face plate. as the face open & closes, over time wares out the cable. problem consists of face plate not opening/closing, display missing & and/or some or all buttons not working. note these can also be intermittent problems. typically the part number is located on the cable itself on the side where it pluggs into the main board. since you have a service manual, you should verify it in the manual. good luck.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
