Cameras Logo
Question about Samsung Cameras
What happens when my Samsung s860 turns on Zooms in a little bit beeps at me then turn back off?
Posted by ROBERT KIRKBRIDE on
How do you download pictures to the computer from the samsung s860
Plug the cable from the camera to the computer, than you turn the camera on, it will prompt you with a menu with two selections, computer and printer, it will already have computer selected, you press ok on your camera and wait a little bit and a menu should come up on the computer screen, should be easy from there.
Samsung s860 makes beep noise and then turns off wont turn on batteries are charged
well i had the same problem it means it doesnt like that type of batterie i find alkyline works best
3helpful
Samsung s860 camera lens will not close and is out of focus.
I hate to say it but your camera needs to be serviced. Might not be worth the repair. Try to take it to a local repair center that would offer you a free estimate....
3helpful
On start-up, Samsung S860 beeps 3 times then turns itself off
first off,never use rechargable batteries in this camera or most digital cameras for that matter.2 use only lithium batteries,enegizer preffered.,also yes you can view all your pictures when connecting the usb,meke sure you turn the power on,and highlight the word computer,push ok.you should be fine.good luck .i hope i helped
Beeps when turning off and pics are blurry
try replacing the battery, cleaning the lens, or fixing the lens
S860 digital camera will not come on.
try to remove battery then put it back then try to press the battery cover while turning on the camera..
Top Samsung Cameras Experts
David Shaub
Paul Bade
Are you a Samsung Camera Expert? Answer questions, earn points and help others
