Car Audio & Video Logo
Question about Eclipse Car Audio & Video
Eclipse 54400 Radio/CD player Locked
I bought a motorhome second hand. It has a Eclipse 54400 cd player/radio installed. How can I unlock the radio to use it?
Posted by George Maehrer on
How do I have to restart my eclipse avn52d car audio cd drive after I changed my car battery ?
You must be inside the Eclipse in order to unlock the radio's security system.
Insert the key in the ignition. Turn it clockwise one notch so some of the car's controls turn on, but not the ignition.
Press the radio's "On" and "Screen/Text" buttons at the same time and hold both down until "SEC" appears on the radio's screen. After two seconds, the screen will change to read "DISC."
Press the "Open" button on the front of the radio. The front panel should open it.
Insert the Key CD into the CD slot. The message "SEC" appears. You should have received this CD when purchasing the car. If you don't have this CD, contact your Eclipse retailer for an extra one.
Eject the Key CD by pressing the "Eject" button and close the front panel of the CD player.
1helpful
2answers
Radio worked, battery replaced, radio light up but does not work?
assuming it displays the message "sec"; eclipse models use a securty cd to generate an new temporary security code and let you unlock it if you have that cd it ok but if not you have to get it or get the whole module serviced at your local eclipse dealer...
6answers
Won't power up. Displays SEC / Help Then SEC / 8D201399 Note the serial number is CD201399. Alan
All Eclipse brand radios have a feature called ESN (Eclipse Security Network) installed. This means a Key CD may be inserted into the head unit so that if the unit is stolen or battey is disconnected from the unit you will have to enter the key CD to unlock the unit.
For example, lets say you purchased this unit from bestbuy. You installed it in your car and you wanted to activate the ESN security feature. You need to choose anyone of your cd's from your collection, lets say you chose The Offsping, Conspiracy of One. Input the disc hit the correct buttons ( I'll explain those later) and your Eclipse 54400's ESN is active.
Now, your 54400 is stolen a week later, the thief will plug in the 54400 into his car and it will show SEC [disc], so he/she will insert a cd and it will say [ERR]. If he or she does this 5 times it will show [call 800] which will lead them to Eclipse customer service, but you will have already called eclipse and told them that your unit was stolen. Whether you get your head unit back is highly doubtful but nobody else will be able to use it.
Now for your answer, to activate ESN:
1.Turn the vehicles ignition on and press the power button 2. Press and hold Radio station preset 1 and the FM-AM button for more than one second 3. Insert the CD of your choice. A [SEC] message will now aooear on the screen and ESN is active. Anytime the unit loses power you will have to reinsert the key cd.
To deactivate the ESN feature:
1. Turn the vehicles ignition on and press the power button or the FM-AM button (make sure the tuner is on). 2. Press and hold the radio station preset button 1 and the FM-AM for more than one second. 3.Once the display flashes [disc] insert the key cd you selected to activate the ESN. The display should now read [CnCl]. The ESN is now deactivated.
To resume normal operation after the power has been disconnected to the unit:
1. Wait for the dispaly to read [disc]. 2. Insert you key cd, if the correct CD is inserted your display will read [---] and the cd will begin to play. If the wrong CD is inserted it will display [Err]. If you insert the wrong CD 5 times it will say [call 800] and then you have to send the unit to eclipse to have it rest. Good Luck!
How to read the Electronic Serial Number:
1. Turn the vehicles power on. Prss the FM-AM button. 2. Press radio preset button 4 and the FM-AM button for more than a second and the display should show your 8 digit serial number. This number is to identify your unit if it is recovered after being stolen. Yep, that will happen!
Keep in mind that the "security code" in a radio basically fulfills this function, ensure that in case of theft, the computer does not work in another vehicle;
I didnt know there was a website to get the radio codes. Before you pay anyone to get your radio security code, I recommend you get on the internet, Eclipse dealers, ask for the parts counter, tell them you need your radio code, have your serial number handy as well as all other numbers off the radio housing.
Or, call 1-800-233-2216 (Fujitsu ten) and they will assist you in the removal of the security code for a $25 charge. the number being displayed is probably the serial number of your unit. If you can remove your radio the SN will be on a tag.
Hope this helps.
4helpful
2answers
I unhooked my eclipse 54400 cd receiver now it is reading call 800 up 7630 dn 1779
I have the same problem what the [email protected]#k is that?? usually you just push the reset button under the volume know(very small) but, this is not working for me, maybe will work for you.
1helpful
2answers
Eclipse 54400
the unit is locked up eclipse has a feature called esn or eclipse security network. you use a cd to program a passkey that only the owner knows. then if it is stolen the unit is useless. unless you know the right cd cool huh? if the unit is registered to you they will help you unlock it but if not they wont. cool huh. kinda makes you feel good that even if someone does steal your radio they cant use it.. ever.. eclipse also offers a one year theft guarantee out of the box if you register it with them. cool huh..
31helpful
10answers
Eclipse AVN-5435
for avn 5435 on the left:press menu and cont ant the same time, while holding them down press menu on the right 5 times
a menu will appear and ask you for a code. you have to call 800-233-2216 and pay $25 for the code. you will have to explain where you bought your eclipse and or know the name of the original owner. if it doesnt match they will not give it to you
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
