Computers & Internet Logo
Question about Toshiba Computers & Internet
Toshiba PX1524E-1HKO, flashing blue/red light
The HDD does not show on my laptop and is flashing a combined blue/red light. The HD does not produce any sound, so I guess it's not spinning. Any clue?
Posted by Olav Stenvaag on
Tesfay
    Passionate:
    Visited the website for 10 consecutive days.
  • 152 Answers
If you're seeing a combined blue and red light on your Toshiba PX1524E-1HKO laptop's hard drive, it means that there is a problem with the drive and it isn't being recognized by the computer. This could be due to a number of issues, such as a loose connection, damaged data cables, or a failed hard drive.
If you're hearing no sound coming from your hard drive, it's a pretty good indication that it isn't spinning. This could be due to a number of issues, such as a failed motor or a damaged data cable.
If you're not sure what the problem is, the best course of action is to take the laptop to a qualified technician or computer repair shop to have them take a look at it. They'll be able to diagnose the problem and let you know what needs to be done to fix it.
I hope this helps!
Posted on Nov 22, 2022
When I restart my laptop to my HD crashes when windows starts to start, she took the laptop outside and put on another laptop to back up, but when it starts copying, the screen goes blue and restarts...
You will have to take the drive off, put it on an external hdd enclosure with a usb connection, connect it to a working computer, scan it for viruses and spyware, copy all of your data to another device (i.e. hdd, flashdisk, cd, etc). Then, reinstall the hd back on to the original computer and turn it on. If it works it you've solved your problem. If it doesn't then reformat your hdd, reinstall your operating system, programs, and data.
Time consuming? yes but it works.
3helpful
Toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
I was restoring the system in my laptop and I have forgoteen to unplug the external hdd toshiba 120 gb mk1234gax hdd2d16. After I have choosen to restore the system of the laptop have initiated, I...
it sounds as that you have flashed the usb port. take the harddrive to someone with a computer and plug it in theirs. if it still does not work remove from case and plug the harddrive straight in to yours.
Toshiba satellite pro 6000 power
Sounds like a bad motherboard to me - assuming that it has memory installed.
5helpful
2answers
1helpful
Toshiba StorE ALU 3.5" external HDD stops out of the blue.
Toshiba could only replace my HD after destroying the data on it, So I just bought a separate empty HD casing instead and opened the Toshiba casing and took out the Western Digital Harddisk. The harddisk was perfectly working, It seems that the Toshiba controller in their casing got messed up. (Never a Toshiba for me, because by solving the problem myself in the appropriate manner I lost their useless warranty).
2answers
Toshiba Satellite A205 laptop will not boot - black screen
Here's a link to a good article that will help you to troubleshoot the startup error. You might also check Toshiba support online and see what the error light code indicates.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
1helpful
Top Toshiba Computers & Internet Experts
David Shaub
Steve Sweetleaf
Steve Sweetleaf
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
