Televison & Video Logo
My flashlight won't power off. a WEATHERX SOLAR POWER FLASHLIGHT & BLUETOOTH SPEAKER
Posted by ROBERT A BELL on
john h
    Top Expert:
  • Televison & ... Master
  • 28,111 Answers
Failed switch
Posted on Sep 25, 2022
2answers
What does the code 5ure mean on 2006 Cadillac CTS?
Make sure the feed dogs are up. Check that the stitch length is set high enough for the fabric to actually advance. AmanStino QUICK CHARGER 3 0 USB charger Multi Port Intelligent USB Wall...
5answers
What kinds of a flashlight the brightest?
Check out this WEB site for super bright LED flashlights.
http://www.nextag.com/super-bright-led-flashlight/stores-html
2answers
I have a camper trailer with 100amp battery and was wondering up to what size inverter i can run iwill be using 60ltr fridge (not running it overnight) a tv and computor
Before you get too carried away, are you aware that no matter what size inverter you are running, you need enough battery capacity to convert to AC (hydro) . 1 x 100 amp battery will not last very long under that load. Do you have plans, or storage space for a few more batteries? How/what are your plans for charging those batteries after usage, such as plugging the trailer in or an external charger, or perhaps solar panels?All that needs to be considered. Look at appliances you plan on running and get the watts, or amps required reading of tags, then it will be easier to calculate for you, and recommend possible solutions.
2helpful
2answers
Flashlight will not keep lighted, only flashes intermittently
i had one extend spring in cap slightly,also check diode is making solid contact with battery
2answers
Problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative cooler to the cold water line coming of it. now there isnt any hot water
water will always find its own level and take the path of least resistance. if your hot water tank inlet is higher than the swamp cooler this may be your problem. you can try a line resrtiction at the cooler or a twelve volt rv pump with a battery and solar charger and an on off switch.know someone with this set up and it seems to work well.
1helpful
2answers
Power Output
Power supply AC 100-240 V, 50/60 Hz Power consumption Copy*1: Approx. 13 W
Standby*2: Approx. 2.2 W
OFF*3: Approx. 0.9 W
*1:When copying ISO/JIS-SCID N2 (printed by inkjet printer) on A4 size plain paper using default settings.
*2:When the scanning lamp is off. USB connection to PC.
*3:USB connection to PC.
1helpful
5answers
Power Supply How To
Because inverters operate from a DC (Direct Current) power source, usually a battery bank (one or more batteries), the battery source will have to be recharged at some point. (Remember that a battery discharged more than 50% is probably close to being dead.) Most cars and trucks recharge their batteries from an onboard alternator. Depending on the inverter load and runtime required, most power use applications will be covered by the charged battery, augmented by the operating alternator supplying a continuous charge to the battery. If the load is large (air conditioner, large draw power tools, large microwave, food freezer, ice cream machine, etc.), the user should verify that the installed vehicle alternator is of large enough capacity to operate the vehicle's power requirement as well as to fulfill the capacity of the inverter load. If it’s not, a motor throttle installation may be required to carry a small load, a larger alternator may be required, or a larger alternator, battery isolator and additional onboard battery bank may be required in order to meet the power requirement of the large load. Remember: it takes 12 DC Amps (at 12 VDC) to run 1 AC Amp (at 120 VAC single-phase) of power because there are voltage and efficiency factors to take into consideration.
Open Questions:
Top Televison & Video Experts
Marvin
Marvin
