Radio Communications Logo
Charger blinking blue light would still charge
2answers
Hoover Blade Stick Vacuum. I don't have blinking blue light and not charged. What is wrong?
Question edited for clarity.
Question moved from Televisions category.
All about blinking lights on Dyson and Hoover. Either the charger has failed or the battery has failed.
https://www.google.com/search?q=Hoover+Blade+Stick+Vacuum.+I+don%27t+have+blinking+blue+light
Bought this blackweb charging station today and when i put my Iphone S on it it just flashes blue tried to readjust the phone and Also unplugged it and plugged it back in but still flashes blue
https://www.quora.com/Why-does-my-portable-charger-blink-and-not-charge
What does it mean when your portable charger is blinking blue? The charger senses this battery condition and as part of it's features gives the blinking indication to say cannot charge this battery. ... A steady charge light usually means that the battery is charging and a blinking light shows that it is charged.
Feb 19, 2019 • Cell Phones
I have a wireless charger for a phone with a Qi chip in it. I am trying to charge my friends phone and the charger is flashing red and then blue. Does that mean it has Qi and it is charging or not?
Silly question, but is your friends phone Qi supported? Normally a red flashing light means that there is an error in charging. It will blink blue when charging and steady blue when fully charged. I am not quite sure what it's erring for, however, red should only blink when there is a problem, so I would have to say that it is having problems and not charging properly. What is causing that I'm not sure, I might trying Googling your particular model of charger and see if they have an FAQ that will explain the lights. This is the best I can offer at this time. Good Luck! Maybe someone else has encountered this and can go a little more in depth.
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Blue light is not blinking or on at all when i set phones on charging dock.
ck that batteries are installed correctly and contacts are clean. Put the old batteries in, if it is not trying to charge them, sounds like the charger is bad.
Blinking blue light
if you have your device hooked up to it, i believe it means it is charging, as i understand it this particular charger can charge multiple devices, the older models of this unti had defects and needed to be fixed, normally if everything is charged, the blinking light would go away and a solid light would appear.
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
1helpful
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
