Televison & Video Logo
I have an RT2911 system, it says 2CH on the display, only the front right and left speakers and subwoofer are working
I don't have a remote, I bought it at a pawnshop, when I first hooked everything up it all worked
Posted by Jaun Olds on
Ma5806 5.1 suround not working
sounds like a problem in the amplifier. what brand is that?
4answers
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
2answers
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
Only the subwoofer, front right, and front left speakers work. Is there a setting that I can adjust to turn the other 3 speakers on? Only 3 of the 6 speakers show up on the display.
When you do a speaker test it should show all speakers, if not then im not sure, but to hear sound from all speakers try pressing mode on remote and change setting to Matrix. Hope this helps.
Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
3helpful
2answers
Surround sound
Hope this helps,
you need to press system menu on the remote..
on the front panel display acually on the DAV unit "DEC. MODE" appears..
Press enter..
Press the up and down buttons to cycle through the options, what your looking for is "PRO LOGIC", "PLII MOVIE" and "PLII MUSIC" ..
Select one of these and this should work.
All the best
1helpful
I have a pioneer gm-x404
The wiring is fairly straight forward. Along the top row of the ten pin plug =
(Left to Right)
Front Left positive,
Front left Negative,
Control wire from your stereo head unit should be thin blue wire sometimes listed as Remote Wire this switches your amp on and off via your head unit so you don't run your battery flat,
Front Right Negative,
Front Right Positive.
Bottom Row=(Left to Right)
Left Back Positive,
Left Back Negative
Centre Nothing
Right Back Negative
Right Back Positive
These are all inputs from your head unit.
To bridge from 4 channel to 2 you connect
one left speaker to Ch B Left Positive and Ch A Left Negative
one Right speaker to Ch B Right Negative and Ch A Right Positive
Ten Switching the Input Select switch to 2CH
Alternatively if your unit has RCA's on the back of the Head unit you can use them to run your subs.
Hope that helps.
2helpful
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Top Televison & Video Experts
Marvin
Marvin
