An expert that got 10 achievements.
An expert that got 5 achievements.
Novelist:
Expert
Re: My gionee p4 has no network after i reset it
If your Gionee P4 smartphone is not connecting to a network after you reset it, there could be several reasons why. Some possible causes include:
Incorrect APN settings: Make sure that the APN settings on your phone are correct and match the settings provided by your mobile network operator.
SIM card not inserted properly: Make sure the SIM card is inserted properly and securely.
SIM card is blocked: Contact your mobile network operator to check if the SIM card is blocked and unblock it if necessary.
Software issue: A software issue could prevent the phone from connecting to the network. Try updating the phone's firmware to the latest version, or performing a factory reset.
Damaged hardware: A damaged radio module or antenna can prevent the phone from connecting to the network. If none of the above solutions work, it could be a hardware issue and the phone may need to be repaired or replaced.
Network settings: Make sure that the phone is set to the correct network mode (2G/3G/4G) and that the network operator is selected.
It's worth trying these solutions one by one and check if the phone starts to connect to the network. If the problem persists, it would be best to contact the manufacturer's technical support for further assistance.
I take it that simply clicking on the brower icon is not gaining you access. Ideally, simply by activating the phone, it should provide you with the internet access offered by your phone's network. If we discard the possibility that you have somehow implemented Bluetooth settings which are interfering with what you are trying to do, there are other things for you to try. If they don't work, you might email the support link offered by Gionee, which appears based in India. https://support.google.com/googleplay/answer/2651367?hl=en
if your gioneer p4 is not getting mobile signal then it may be problem from the kitkat and or the ios so you have to upgrade it by following these process https://www.dropbox.com/s/7e7ztb5v9lq2b6e/Materialmod_by_Swisscarter.zip?dl=0......little guide on it Material ROM users download that file a flash via recovery!! See proofs
Signal icons to the left
Signal icons like iOS style
Framework mods too
Material ROM v3 users only
https://www.quora.com/How-do-I-reset-my-Gmail-password-when-I-...
QuoraMay 7, 2012 - How do I reset my Gmail password when I don't remember my recovery information? ... Unfortunately if you can't remember the username or the recovery address, you might be out of ... Search with "change password in gmail"Missing: gionee m3
