Question about Advance Audio Players & Recorders
My sounddock power input is stuck in,i am concerned to force it ,any solutions ,thanks in advance
3answers
Bose SoundDock. The remote battery cover is stuck. I can't remove it?
Question edited for clarity.
Bose SoundDock Portable v2 Remote Battery Replacement
  1. Step 1 Remote Battery. Using a quarter, turn the battery cover 1/8th of a turn counterclockwise.
  2. Remove cover and battery. The new battery should be placed with the positive (flat) side facing up. The correct battery for your remote is a CR2032.
Pictures as well
https://www.google.com/search?q=Bose+Sounddock%2C+replace+remote+battery
2helpful
2answers
Missing power back bose series1 sounddock
If i'm not mistaken you can find those on Bizrate.com.
5helpful
2answers
I need the Bose SoundDock schematics
No, but I have repaired many without a schematic. Aside from damage, there are abiot four basic failure modes. Tony
6helpful
When i plug in my sound docking station it makes a knocking sound
The only 2 possibilities are: 1. The power supply IS bad and needs to be replaced. (not the cord, but the supply itself) 2. The 4-prong power supply plug at the back of the SoundDock isn't connecting properly (try flipping it upside down, or making sure "DC power" is written on top if it's a later version.)
If this is the SoundDock Portable or SoundDock II, then the problem is definitely the supply.
Bose can send a new supply for $50+, or repair a non-warrantied SoundDock for $99.
2helpful
Plastic shroud pulled out of docking station power port.
If the 4 input jacks on the back of the SoundDock seem to be okay, then just order a new power supply. If this is not the case, send it in for repair ($100) which upgrades the SoundDock to be able to use the newer iPods (iPod touch 2nd gen, new nano, iPhone 3G)
They give you a new 1 year warranty as well.
3helpful
Missing power cable for Bose Sounddock
Repair may the only solution. The new power supply is only slightly different though.. If you don't want to spent the $100 to repair this, you could get the new supply and carve a notch in the top part of the square power input.. Looking at the new power supply, the top is a bit taller and arched but the same specs..
But the new power supply is still expensive. (I think $60+) So for an additional $40 ($100 total) you can get a new supply retrofitted on to the old input. It's worth it- you get a new 1 year warranty, and they put the new Apple dock connector on there (USB charge pin) as well as the power supply, so you can use current iPods as well as old. (Your SD currently won't support- iPhone 3G, iPod Touch 2ng gen, or iPod Nano 4th gen.. it will after a repair)
Stuck in power save mode
Have you have selected the input you are using? You can switch between analog and digital input. The monitor would stay in power save if the input other than the one you are using is selected.
I believe the default input is DVI. Are you using VGA?
In the menu, under advanced, you can select the input.
Menu rotates
Had the same problem with the Mitsubishi ws 48511 model. A solution posted in FixYa worked great and might be worth trying as they have very similar electronics and panels -- did you check to make sure that one of the front panel buttons isn't stuck in the depressed postition? For me, the device menu kept cycling and remote wouldn't work. Sure enough, the button was stuck pushed in. It was hard to even notice, but took little effort to get it free. Good luck.
Top Advance Audio Players & Recorders Experts
Ginny Larson
ADMIN Andrew
ADMIN Andrew
ray gallant
Are you an Advance Audio Player and Recorder Expert? Answer questions, earn points and help others
