Question about Crosley Audio Players & Recorders
How to adjust speed the record player back to normal on top my Crosley McQueen stereo?
I have a problem the record player on top my stereo. The 33 1/3 rpm is fast like almost 35 or 36 rpm. My stereo is Crosley McQueen. Can you please help me? How to adjust speed back to normal like 33 1/3?
HOW DO I ADJUST THE SPEED ON A CROSLEY CR47 RECORD PLAYER
There should be a speed control switch in the upper right side near the arm.
I found a CR-48 manual with a picture at page 4 at the link shown. That should be similar to the CR-47
Crosley CR 48 Instruction Manual Control Locators Getting Started
Crosley troubadour stops before record is done
Check to see if there is a switch setting for 7", 10", and 12" records. Sounds like a switch setting to me. Does it always pick up at the same physical location on any record? If so, that is the likely cause. Personally, if you have an extensive collection of vinyl, a Crosley is definitely NOT the best turntable to be playing them on. You'd get way better fidelity and save your records from physical groove damage by investing in a better turntable. If you want the collection to stay in good shape and retain their value, ditch the Crosley ASAP.
1helpful
Brand new crosley keepsake that spins too fast even at its slowest speed setting (33 1.2). Can I fix or should I send it back for repair?
If it is belt driven it could be that the belt is not moving to the smaller diameter pulley for the slower speed. But the unit is new so I would just return it for an exchange at the store it was purchased from. It is new - the heck with a repair - just get another one!
Crosley Cruiser turntable vibration noise
How to Identify Damage in Your Record Player ' eBay
www.ebay.com > ... > Record Players/Home Turntables
They produce audible sound by reproducing sound vibrations from tiny grooves etched on the surface of vinyl records. Record players have three primary ...
Crosley Cruiser Turntable Review - YouTube
? 2:26
https://www.youtube.com/watch?v=w5KVANeimVU
Dec 8, 2013 - Uploaded by DTM
This is a review of the Crosley Cruiser turntable. ... cartridges (the mechanism that converts the vibrations of ...
Just getting into vinyl. Is there any way to improve a Cros
2answers
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Even though i am playing my record on normal speed, it plays to fast
if your turntable doesn't have a pitch control (like the dj's turntables) if you open it you should find on the board close from the 45-33 rpm switch a variable resistor ( a small electronic part with a sort of disc on top with in the middle of it a place for a flat screw driver and marking like + and - those resistor are made to control the speed and can go bad or just need to be adjusted . First try to adjust it turning the dial really carefully with a small screw driver if nothing happened it could need to be replace.
How to adjust AIWA Turntable PX-E860U speed
Found this post trying to troubleshoot my Aiwa PX-E860U-after replacing the belt and lubricating bearings, the speed was off. 33 setting was playing slow. Here's the fix:
1. unplug and flip upside down
2. Locate the two holes marked 33 & 45 where black dots are visible underneath
3. Using a very small flat screwdriver(I used one from an eyeglass repair kit), adjust the speed clockwise for faster, counterclockwise for slower
this is a DIY solution, so not perfect, but it works. I played the tracks along to a Spotify recording to get a good match. Hope this helps someone else!
AFTER adjusting the speed setting to 33, all the records are playing too fast, they sound like chipmunks. I tried all three settings and while each speed is different from each other they all seem to be...
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
4helpful
2answers
Crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
I just bought a crosley record player and the 33 1/3 speed plays too fast.
How close are the other speeds? Chances are - especiall if you a musician - that the 33 1/3 speed is "generally" close, but not guaranteed that accurate. How far off do you think it is?
Depending on what you tell me, I'm not sure that PRACTICALLY there's a remedy. Let me know.
Top Crosley Audio Players & Recorders Experts
Morne Olivier
Morne Olivier
Steve
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
