Heating & Cooling Logo
Question about Emerson Heating & Cooling
I NEED A CENTIFURGAL SWITCH REPLACEMENT FOR EMERSON T63BXBYF1133 240v AIR COMPRESSOR MOTOR
The pump is no longer made and I want to rebuild it but can't find a switch that crosses over. Any way to size these things out? Single phase, 240v, 3450rpms
Posted by Jason Pennington on
2answers
Where to get a Generic Air Compressor Belt 1 wide flat with Splines long ways not across.
Have you tried contacting some compressor repairers and suppliers directly and on the websites? They often carry various belts in stock and should be able to help you.
1helpful
Emerson Hi-efficiency1081Pool mtr.EUSQ 1202 mod T55CXCJK-1345 for sprinkler 2.0 hp. Blown internal seal
the seals are replaceable/ the motor is a C faced motor it is quite possible water got into motor. Mechanical seals should not be replaced by homeowners, they want to to touch seal faces and this will destroy seal. Look locally for business that install water pumps and let them handle it. The motor will need to be rebuilt so check price and compare to new motor around $250. If the rebuild is half or greater replace with complete new unit.
Replace water pump
fix it, but the longer you let it run the more damage done, search your area for your local pool pump repair guy with free testing,
some of these pumps can be CRAZY expensive NEW but cheap to fix/rebuild/repair/bearings.OR a suitable replacement motor might be avalibl FYI
2helpful
Electric compressor motor problem
Unloader valve on switch. That switch is not bleeding off cylinder head pressure,when it shuts off.
1helpful
Will not fill with air where can I get parts?
Below is a link for parts to a Coleman compressor model #VPP0200604. Not positive but I think that is what you have.
However before you buy anything how do you know what the problem is? Is the motor running? If the problem is that it's just worn out you may find it difficult to get parts for rebuilding it. What you have is whats commonly referred to as a throw away pump. The second link show the pumps replacement cost, around $85.00. If you do manage to get rebuild parts for it they will cost at least that much.
You can get a Senco at Home Depot which is a couple grades up from yours for around $125.00.
Your compressor is really not worth the effort to rebuild it.
If on the other hand your compressors motor is not starting up please include any details in a response to this and I'll try and troubleshoot it for you.
Hope this helps.
http://www.mastertoolrepair.com/vpp0200604-vp0200604-p-14827.html
http://salestores.com/colema14.html
1helpful
Craftsman 3 gallon 1hp. Motor runs but no pressure buildup. Oil level okay and no obvious leaks.
Your motor is good and your pump is in need of being rebuilt. I would price both the rebuild and the cost of replacement all together as there are many good cheap used compressors crying for a home.
9helpful
Air compressor fills, but slows down as the pressure builds
sounds like you need a new check valve which should be somewhere between the compressor outlet piping,tubing,etc and the tank which prevents the air in tank to back feed to the compressor which would cause hard starting and could damage the motor easy way to check is when you shut off the compressor with some air in the tank if the check valve is bad it would continue to bleed air out out the unloader valve .the unloader valve on your unit is most likely part of the pressure switch when the unit shuts of it should only bleed down the pressure in the pump so it would make it easy to start when needed hope i didn't confuse you
Top Emerson Heating & Cooling Experts
shizznat
Level 1 Expert
Jay Finke
Jay Finke
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
