Vacuums Logo
Question about Hoover Vacuums
The brushes on my Hoover model #5899-100 are not turning. How can this be fixed?
Posted by St Bernadette... on
2answers
A hoover uh70400bca the bottom brush stopped turning the belt is good
dont know that model but usually the brush roll clips into the front
and comes out wuth a firm pull. the metal ends on mine unscrew
usually hair, cotton, etc packed in round bearing, clean up spray with WD 40 and grease the bearings.......jobs a good 'un
I cant get my hoover vaccum brush to spin
First be sure the switch/circuit breaker on top of the nozzle is on. The brush also will not turn unless the handle is released and tilted back. This model of Hoover has a gear drive to turn the brushes. This was VERY prone to problems, and Hoover discontinued making replacement parts for it several years ago.
2answers
Is my 6215-900 brushes drive driven by a belt? I
No, there isn't a drive belt on the Hoover Steam Vac models.
1helpful
Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
I have a hoover windtunnel v2 the brushes underneath wont turn ? its suppose to be beltless what do i do to fix this
Are you sure it is beltless? What model do you have? Looking at another manual there may be a seperate on off switch for the brushes but would need to know your model to be sure.
2answers
Brushes won't turn on a Hoover F7426-900
there should be a rubber belt that drives the brushes on either side. hope this helps. please rate this.........thanks
Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Mar 18, 2008 • Vacuums
2answers
Hoover cleaner model f5865-900
There is no belt, either the turbine part #43191003, or the brush block, the shaft that goes up into the turbine broke off part #48437022. The turbine is what drives the brushes.
1helpful
Brushes turning slow on Hoover F5881-900 steam vac
there is a part inside called the turbine which needs to be replaced or cleaned. Also clean the brushes.
Top Hoover Vacuums Experts
Marvin
Marvin
Mike
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
