Expert
- Posted on Feb 26, 2023
Re: How to remove pinion gear on a 609 chefs choice
To remove the pinion gear on a Chef'sChoice 609 electric food slicer, follow these steps:
- Unplug the slicer and make sure the blade is fully retracted and locked in place.
- Remove the food carriage and the blade cover.
- Locate the pinion gear, which is the small gear that meshes with the larger gear on the blade. It is attached to the motor shaft.
- Use a small wrench or pliers to remove the retaining clip or screw that holds the pinion gear in place.
- Gently pull the pinion gear off the motor shaft. It may be tight, so you may need to wiggle it back and forth or use a gear puller to remove it.
- Once the pinion gear is removed, you can clean it and inspect it for damage. If it is worn or damaged, you may need to replace it.
- To reinstall the pinion gear, simply slide it back onto the motor shaft and secure it with the retaining clip or screw.
- Reassemble the slicer and test it to make sure it is working properly.
It is important to note that removing or replacing parts on an electric food slicer can be dangerous and should only be attempted by someone with experience and the proper tools. If you are not comfortable performing these steps, it is recommended that you take your slicer to a certified repair center for service.
