Dishwashers Logo
Question about Asko Dishwashers
I can't get power unless I unplug and re-plugin. How can I fix / resolve this issue? Thanks for the help, make ASKO Model # DF1664. .
Posted by Christopher Whalen on
  • Scott Waterhouse
    Scott Waterhouse Oct 14, 2022
    I have the same problem with DW40.1
ASKO DB1664 power issue-can't run unless you unplug and plug back in
Jros, i moved you of of computers to DISHWASHER.
the appliance needs service. call for service;. in you town.
no service manual/?
how long have you used it, 1day 1 year? ? or first ever AC power failure ever by you.
it might have battery inside, to retain settings, in the control head
some home appliances, a AC power service entrance, AC POWER loss do lose settings or only time of day. and must be reset. only reading the manual cures that or do the test.
why not call the factory , and ask
USA is here (if not USA click country icon top right of there page.
ask them for answers to that question.
https://www.askona.com/dishwasher
2answers
I can't get power unless I unplug and re-plugin. How can I fix / resolve this issue? Thanks for the help.
Is this with an Asko Dishwasher? You give no clue apart from the category. All posts here really need full
make model (what it is )
My guess is a bad connection or a faulty mainboard.
1helpful
My asko dishwasher will not turn off. The pumps runs but nothing happens. The dial has no control over the machine at all. I have turned off the breaker but wonder should I order parts or can it. We...
Hello Steve,
Welcome to FixYa.
As an Asko expert and based on your post, the good news...I can fairly confidently tell you It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What the pump running continuous means is the timer has indicated a overfill.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit and the continuous pumping is
letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary.
Good luck.
Regards,
Macmarkus :)
I have a Acomdata 500 Gb external hard drive. Model #: BIO500UE Ser#: B1001756. After typing in my password, I get the following msg. The secure device might be abruply removed or unplugged. Please...
Unplug, restart, plugin.
If that does not work restart your system with a life linux cd (does not install) and connect drive.
http://www.linuxmint.com/download.php
3answers
We had a power cut which has affected the power of the oven. Power is now on, lights are flashing but, as i have lost my manual i don't know how to get things started.
Hi
Thanks for using FixYa. To start with unplug the oven and plug it back after 10-15 minutes, if still the issue is not resolved then the control panel has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 06, 2010 • Ovens
2answers
F2 error message after dishwasher backed up when draining. Asko brand.
Hi
Thanks for using FixYa. Error F2 in your Asko Dishwasher means high water level. This error occurs due to plugged/bad water pump and/or a bad inlet valve. If the water pump and/or water inlet valve are bad it should be replaced to resolve this issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 • Dishwashers
1helpful
Whenever i plugin my lappy for recharging my system is not charging my system shows (plugged innot charging).
To resolve this issue, download and install the latest BIOS Update for your notebook from the manufacturer site. Later perform the following steps:
Power Management reinstall:
1. Click Start, type "device manager" in search tab.
2. Locate device manager from search list and pen it.
3. Click "+" beside System devices.
4. Select ACPI Fixed Feature Button.
5. Right-click the device and select Uninstall.
6. Restart the system.
Blinkinkg light
Go here, enter your model number, choose solve a problem, and see errors diaplayed on your product or search error lights or blinking lights. You'll get instructions for your printer. You may need to reset it by unplugging both data and power cables for awhile, then reconnecting.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
1helpful
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
5helpful
3answers
ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Top Asko Dishwashers Experts
Marvin
Marvin
David Shaub
nu267
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
