Kitchen Appliances - Others Logo
Question about The Kitchen Appliances - Others
Hi I have a Lincat lpg silverlink df4 fryer gas LPG. It lights but the cuts out after 15/20 minutes? Could anyone help please
The fryer lights perfectly however after approx 20 mins it will cut the whole fryer out. As if it's over heated. Any idea which part this might need replacing? Thank you
Posted by Jordan Hogg on
1helpful
Yellow flame black smokePitco 24f 6 burner Lpg Pitco fryer yellow flame on Lpg orifices size 53# Neww burners new gas valve set up on 10 wc. 2 technicians came over but no result
yellow flame and black smoke is incorrect air /gas ratio
there is an air shroud over the jet that controls the air flow mix and it can be adjusted forward or back to open / close the air inlets holes
could be that the jets are incorrect for LPG as the indications are the same if running on LPG with natural gas jets
Rpm 30 mph
IF you are on lpg then check that the gas regulator for icing up and stopping the liquid LPG from turning to gas. If it cuts out on petrol check that there is not a problem with the petrol shut off solenoid . Check the LPG cut off solenoid . I suspect a loose connection or wires to either or both or faulty units
Hi all i have a AGA MASTERCHEF Model 100 DF Serial number D0000124 and cant find LPG coversion Kit AGA says no kit can anyone help please Mal
Hi I have the same problem - mine is LPG and I need to convert it to NG... if anyone has any solutions I would be really grateful.
Thanks - Juliz
Vxr keeps cutting back to petrol from LPG.
control module for crossover not working either bad pressure sensor or control
Imperial ifs 40: gas comes out of jet and the burners work fine for a moment, then the flame ignites inside the burner and makes a worbling noise every now and then popping. is this low gas...
Check your manual and make sure your burner is configured for the gas that you are using. In most cases, there is an orifice that needs to be changed for using LP, or a screw setting that needs to be changed- most new appliances ship with a "city gas" configuration ( AKA NG - Natural Gas) and need to be configured for LPG (Liquified Propane Gas). The fitting(s) that need to be changed are tagged. This is due to the pressure difference between NG and LPG. Propane (LPG) runs at a higher pressure.
You state that your fryer is LPG. If you are running it on NG ("city gas") you need to consult your manual for converting it to NG. Outside of making sure that you are set up for the right gas, you should not have to make any other adjustments. For safety reasons, gas regulator pressure adjustments are for the most part no longer possible on gas appliances.
1helpful
2answers
Started car running on petrol for 5 minutes with lpg switched on, clicking noise from lpg tank, slight smell of gas, when fuel switched to lpg engine cut out. start again on petrol, switch on lpg again,...
could be number of problems but often this is caused by valve on the inlet manifold which is electricaly operated and then it allows the gas in but it is also vacumn sensitive so a perished rubber pipe could cause it not to sense the vacumn .best advice without seeing it is to visit a mechanic that is conversant with LPG conversion
Top Kitchen Appliances - Others Experts
vince
Marvin
Marvin
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
